R50/53 squeaky noise from engine
Old Jan 21, 2017 | 05:08 PM
froggy_07's Avatar
froggy_07
serpentine belt replaced 2 weeks ago. Have is nasty sound now. Any suggestions on what it could be? Or what would cause this or how to fix.
https://youtu.be/6Sgz0xs2AUA
thank you
Old Jan 24, 2017 | 08:41 AM
BruceJ's Avatar
BruceJ
Sounds like the belt tensioner or another pulley.
Pull passenger wheel and the passenger wheel shroud. Get a couple empty paper towel tubes, tape together and put one end to your ear and the other towards the suspected areas. This will narrow down where the noise is coming from. Yeah I know its not easy to get to each area, but you asked.
You can probably get away using one but I use two to help my hands away from moving parts.
Otherwise I have seen folks try WD-40 one pulley at a time.
Good Luck
Bruce
Old Jan 24, 2017 | 09:03 AM
X757XVeritas's Avatar
X757XVeritas
Another good thing to use would be a long socket extension or some sort of metal rod. Sound travels farther through solid objects.
Old Jan 24, 2017 | 09:31 AM
Eric_Rowland's Avatar
Eric_Rowland
My idler pulley started squeaking - discovered by squirting with WD40 - sound goes away (for a short time). A bit easier than the other methods.
Old Jan 24, 2017 | 10:16 AM
froggy_07's Avatar
froggy_07
it will make it not so loud but after i find which one it is, it will eventually need replacement
Old Jan 24, 2017 | 10:22 AM
froggy_07's Avatar
froggy_07
I appreciate the input and solution to this sound.
Old Jan 25, 2017 | 08:31 AM
froggy_07's Avatar
froggy_07
took the wheel well apart, listened closer to where the noise was coming from. Sprayed the pulley WD 40. noise started to disappear after 1 little spray. sprayed more until it was gone. Thank you. heres a video. The pulley will need to be replaced sooner than later, correct? Anyways Thanks a bunch!
https://youtu.be/G8MXunAxFB8
Old Jan 25, 2017 | 06:37 PM
BruceJ's Avatar
BruceJ
Glad you found it. Replacing sooner, is always better than the side of the road, awaiting Tow Truck.
Good Luck
