R50/53 No power on ac controls
Old Jan 16, 2017 | 10:35 PM
rensai's Avatar
rensai
I finally was able to get my hands on a 3 pin blower fan. After installing it I turned on the car and noticed that when I tried to turn the ac on nothing happened, Double checked all connections and fuses and still no power to the ac controls. Have any of you guys had this issue before? Any advice will be greatly appreciated.
Old Jan 17, 2017 | 07:48 AM
MiniToBe's Avatar
MiniToBe
there is no cold, no hot air coming out? no fan? no ac compressor kicking?
Old Jan 17, 2017 | 07:58 AM
rensai's Avatar
rensai
There seems to be no power going to the automatic controls since none of the lights come up.
Old Jan 17, 2017 | 08:07 AM
MiniToBe's Avatar
MiniToBe
did you accidentally unplug the controller? double check the connectors and press them firmly.
Old Jan 17, 2017 | 08:10 AM
rensai's Avatar
rensai
I unplugged them when I removed the dash to get to the blower fan. It's a 2003 Mini S. But I made sure everything was plugged in before trying to turn the ac on.
Old Jan 17, 2017 | 08:14 AM
MiniToBe's Avatar
MiniToBe
if it isnt a hassle, try to check them again. I am not too familiar with R53 but, did you disconnect the battery and reconnect to reset the module?
