code P0087
Old Jan 2, 2017 | 08:51 AM
Wanderlustsrt's Avatar
Wanderlustsrt
code P0087
Got a check engine which disappeared when i turned car off and on and is not easily reproduced but does come back about every 30 miles on its own. Code P0087 which my OBD 2 reader says is fuel system. Does NOT happen under hard acceleration or anything perticuler I could discern. Any ideas? Will take it into mini dealer if i cant figure it out. 2011 R56 Cooper S
Old Jan 2, 2017 | 09:07 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Probably High Pressure Fuel Pump is starting to fail. 2011 cars seem to be covered under an extended service bulletin. In my case they threatened to charge $99 to diagnose, but wiped that off and I paid zero for a replacement on a 2011 N18 engine.
Good luck.
Old Jan 7, 2017 | 05:25 PM
Wanderlustsrt
I replaced gas cap and it seems to have fixed the issue. Im going to get it checked out anyway but so far so good.
Old Jan 16, 2017 | 12:03 PM
Wanderlustsrt
Yep light went back on last friday, I had an appt in advance at mini dealer. Took it in and they confirmed it was HPFP pump as you suggested. They are replacing it for free today. Thanks again!
