Electrical 2012 JCW Battery Replacement - not rocket science
Old Dec 20, 2016 | 06:05 PM
troyegly's Avatar
troyegly
Hello,
I am in search of a replacement battery for my car. I have done some extensive searching and do not know why it is so complicated to find what is the replacement.
I thought it was the H5 (BCI Group 47) type battery I needed but every battery I look at has the terminals on the wrong side!
I need negative on the right.
Any help is appreciated
Old Dec 20, 2016 | 08:42 PM
3lusive's Avatar
3lusive
I replaced the battery in my 08 MCS and used a Duralast H5 DLG. Fit perfectly and no problems with terminal orientation
Old Dec 21, 2016 | 09:01 AM
troyegly's Avatar
troyegly
Thanks for the reply, maybe it is different for the 08 vs 12 as I need the negative terminal to be on the right side when facing the battery.
I looked up the battery you mentioned and the negative is on the left side.
Old Dec 22, 2016 | 08:35 AM
3lusive's Avatar
3lusive
Hmm I don't see why they would make a change like that. If you rotate the battery 180 degrees so the terminals are on the correct side then it should work. I think that's how the Duralast would be oriented too, because from this thread the terminals are on the rear of the battery:
https://www.northamericanmotoring.co...-pictures.html
Old Dec 22, 2016 | 12:36 PM
troyegly's Avatar
troyegly
True dat, I was being stupid! My car is in the shop and I was thinking the terminals were located in the front when the batter is installed, but now that I think about it they are in the back
