R56 2007 R56 won't start, new battery
Old Dec 16, 2016 | 05:45 AM
midacl's Avatar
midacl
After lunch yesterday, my Mini didn't want to start, it just clicked. I popped the key out, and back in. After that it started up, albeit a little slower then normal. After work, same thing, but this time popping the key in and out didnt help. Eventually I got someone at work to help me jump it, and it fired right up.
I picked up a new battery, and installed it. But didnt bother trying to start it last night. When I went to start it this morning, it just clicked.... I didn't have much time to waste trying to figure out why, so I drove my truck into work today.
What should I look at tonight when I get home? I am 99% sure I tightened both terminals enough, and checked that they did not rotate. And everything else seems to be working. Its in my heated garage, so its not sitting outside in single digit weather.
Old Dec 19, 2016 | 09:20 AM
MiniToBe's Avatar
MiniToBe
can you get a voltage reading at the terminals (not batt posts)?
Old Jan 18, 2017 | 07:24 PM
MiniToBe's Avatar
MiniToBe
Any updates, what was the solution if any?
Old Jan 20, 2017 | 05:48 PM
Kcblackwell07's Avatar
Kcblackwell07
Try cleaning the terminals and the wires with a terminal brush even if they look clean.
Old Jan 21, 2017 | 07:54 AM
NikiMae31's Avatar
NikiMae31
I had my battery die on me, but it was the original battery. Once I replaced it, I needed to have the new battery registered to the car by my Mini dealer. Dunno if you could jump it and get it into the dealer to have it registered.
Old Jan 21, 2017 | 08:01 AM
JPMM's Avatar
JPMM
I replaced my battery without registering it and it worked OK.
