R56 Rear brake wear sensor light wont go away
Old Dec 13, 2016 | 12:23 PM
squeegebrb's Avatar
squeegebrb
So I've been fighting an intermittent yellow/red brake light and service light. The code is 071 which apparently is the rear brake wear sensor. So I replaced the sensor, the light came back on after I hit a bump in the road. I took it all apart, replaced my brake pads(they weren't close to needing to be replaced but I was upgrading anyway), and I replaced the sensor again(thinking it could have been faulty), then I reset the light. Voila! Light was gone.. 30 seconds of driving, I hit a bump, the yellow brake light comes back on for the sensor. I even took one of the old sensors and twisted the wires together with some shrink wrap, a slight bump in the road continues to cause the light to come back on.
Old Dec 13, 2016 | 12:45 PM
MiniToBe's Avatar
MiniToBe
make sure the sensor is pushed all the way in the pad. it should lock in place.
Old Dec 13, 2016 | 12:53 PM
squeegebrb's Avatar
squeegebrb
This has been done. I am currently running with the one that has the cut off end wired together and still having the same issue after resetting the light. It's fine until I go over a bump in the road. I am wondering, could it be a relay, fuse, or even possibly a break in the wire farther up.
Old Dec 13, 2016 | 12:55 PM
MiniToBe's Avatar
MiniToBe
mmmm, if that happens again (driving over a bump and the light comes on), did you try to reset the service without actually touching the sensor?
Old Dec 13, 2016 | 12:58 PM
squeegebrb's Avatar
squeegebrb
Yes. I've done it a couple of times just to assure that's the issue. The last drive I had I drove for around 5 minutes before I hit a big bump in the road that always seems to trigger it and sure enough the light popped back on.
Old Dec 13, 2016 | 01:03 PM
MiniToBe's Avatar
MiniToBe
i think the wires goes all the way to the fusebox or ECU. do you know if the front one is also doing that?
Old Dec 13, 2016 | 01:09 PM
squeegebrb's Avatar
squeegebrb
No issues with the front sensor at all. MINI replaced brakes and rotors all around about 6 months ago too.
Old Dec 14, 2016 | 05:32 AM
NB Cooper's Avatar
NB Cooper
It sounds like you have a damaged wire somewhere between the rear connector and the computer. You will have to inspect the wire till you find the failure point and do a repair.
