Hi guys, on the weekend i replaced my rear pads and rotors. After completion, i took her for a spin, and found the brake light on. I put the car back up on the jack and replaced the brake sensor with a used one i had lying around. Now all 3 of the lights mentioned above are on, along with the engine light. (all of which were not on before)
Any thoughts?
I believe it's a wheel speed sensor. I talked to mini the other day about it they said that's more than likely what it's from. Also the front two are more susceptible to becoming dirty/breaking.
You might have bumped the connection at the wheel speed sensor with the brake pad sensor. They have to be clipped in and set. Did you maybe mix up the two? Also it has to be clicked in all the way..
