R50/53 Belt tensioner dampner removal question
Old Dec 10, 2016 | 04:49 PM
GoThingNC's Avatar
GoThingNC
Do I need to lock the tensioner before removing the dampner to replace the bushings?
Old Dec 10, 2016 | 09:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You can just pull the tensioner shock off. That is how we do it when we install our WMW delrin bushings. You don't even have to compress the tensioner.
https://www.waymotorworks.com/wmw-su...shing-set.html
Old Dec 11, 2016 | 05:46 AM
GoThingNC's Avatar
GoThingNC
Awesome, thanks Way.
By the way, I have your set of tensioner bushings in my tool box. I should have used them when I replaced the tensioner assembly 30,000 miles ago.
I was very lucky, rattling noise suddenly got louder so I took a clise look at the tensioner bolt near the firewall and I was almost able to slide the end of the dampner over the bolt.
Old Dec 11, 2016 | 10:58 AM
sherman89's Avatar
sherman89
I just did a damper replacement and a 13mm ratchet wrench really helps to speed up the process----there is little room for fingers and no room for a socket/ratchet. As Way says you do not need to detension the belt. Which bushing went out ---the top/away or the bottom/close to the belt
Old Dec 11, 2016 | 01:18 PM
GoThingNC's Avatar
GoThingNC
I took the wheel and fender liner off to acess them.
Both bushings were toast.
Old Dec 11, 2016 | 05:46 PM
WayMotorWorks
Vendor
That's pretty normal for those old bushings.
Old Dec 12, 2016 | 09:00 AM
sherman89's Avatar
sherman89
If the bushings are that bad the shock is probably done.
Old Dec 12, 2016 | 09:06 AM
GoThingNC's Avatar
GoThingNC
I compared the shock with a new one and the pressure is about the same.
