R50/53 Windshield wiper sprayer stopped working??
Old Dec 6, 2016 | 10:51 PM
Stripeknight's Avatar
Stripeknight
Windshield wiper sprayer stopped working?? Is there a common fix for this? I checked the fluid level but it still won't work..
Old Dec 7, 2016 | 03:46 AM
mdaz75's Avatar
mdaz75
A year ago I had the same problem. No spray on front or rear window. No motor sound when activating the washer function. I ordered a new motor, installed it and still nothing. It's like no power is getting to the motor. All fuses are fine. I got side tracked and pretty much forgot about it, but now winter is here and your post reminded me to get my *** in gear. Sorry no solution.
Old Dec 7, 2016 | 04:52 AM
IQRaceworks's Avatar
IQRaceworks
I had the same problem, turned out to be that one of the hoses that runs from the pump motor up under the hood to the sprayers came lose. I had to pull some of the insulation off to find it.
Once I plugged the hose back in, it fixed the problem
Old Dec 7, 2016 | 02:24 PM
Can you hear the washer motor run?
Old Dec 7, 2016 | 05:55 PM
Whine not Walnuts's Avatar
Whine not Walnuts
And like where do you live, any sub freezing temps yet? If yes, did you have summer or winter mix in???
Old Dec 7, 2016 | 07:24 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
See if anything comes out when the hood is lifted.....
The black washer feed line hose on pass side going to hood coming in from below windshield corner often gets kinked once the bonnet is closed.....make sure it is properly placed / secured and close bonnet.
Old Dec 7, 2016 | 09:10 PM
Stripeknight
Thanks for all the great tips I will try them out and yes it freezes where I live int he California mountains once in awhile, I did not have freeze protection in the wiper water but it seemed to be a problem during the summer when it was warm. I can't remember hearing the motor but I'll check
