Drivetrain Boost or Boost/Vacuum gauge?
Old Dec 1, 2016 | 02:35 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I want to add a boost gauge to my Clubman. I have a 2012 model with the N18 engine, and I know the manifold will mostly only show boost, and not vacuum.
What are your thoughts about adding a boost only gauge, instead of a boost/vacuum gauge?
Old Dec 1, 2016 | 05:13 PM
DneprDave's Avatar
DneprDave
Actually, it shows vacuum more than boost. Get a gauge that shows both.
One benefit is that you can maximize fuel economy by keeping the needle in the vacuum range as much as you can.
Old Dec 2, 2016 | 05:29 AM
randeez's Avatar
randeez
the n18, after "warm up" will only show about 5" of vacuum max, will usually hang around 1-3", however I would get a gauge that does both - it would be an easy indicator if something weren't working correctly to see a lot of vacuum under normal conditions
Old Dec 2, 2016 | 06:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
that is an excellent point. i'll get the boost vacuum gauge
Old Dec 2, 2016 | 07:19 AM
DneprDave's Avatar
DneprDave
A vacuum gage will read in inches of mercury, not psi.
Old Dec 2, 2016 | 10:07 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Check out the Cravenspeed mount kits and Marshall gauges.
