Power Steering leaks anyone?
Old Dec 1, 2016 | 01:07 PM
traildog's Avatar
traildog
While I'm fixing everything else I might as well figure out why the PS hoses are wet from the reservoir on down.
Is the reservoir itself prone to leaks or just the hoses?
No way for.me to tell if they were ever changed.......
Old Dec 1, 2016 | 01:15 PM
JAB 67's Avatar
JAB 67
its the hoses . . .
Old Dec 1, 2016 | 01:57 PM
traildog's Avatar
traildog
Originally Posted by JAB 67
its the hoses . . .
You're sounding mighty sure of that JAB........
I'm headed out to yank them off right now.
Old Dec 1, 2016 | 07:36 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's not the reservoir as they always look wet since they have a hole in the cap that is a vent for the pressure.
The lines are very common to leak as we replace them in our shop all the time.
https://www.waymotorworks.com/r50-53...tion-line.html
Old Dec 2, 2016 | 02:04 AM
traildog's Avatar
traildog
So it's just the suction line most likely?
Old Dec 2, 2016 | 04:13 AM
Kaniyrret's Avatar
Kaniyrret
The 2 cars I had leaks on were just the clamp at the top. Then it drains down inside the heat shield.
Old Dec 5, 2016 | 10:25 AM
nkfry's Avatar
nkfry
Many times you can fix leaks with removing the factory crimp clamps and replacing them with worm style clamps, but more often than not it is the return line leaking at the crimp connection.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 7, 2016 | 11:49 AM
gumbedamit's Avatar
gumbedamit
I can see my hoses are weeping, no significant fluid loss; 2 months in and I've not had to top off the fluid. On the back burner for now, other leaks are more prevalent that need to be addressed.......
