R50/53 Supercharger and WP question
Old Nov 23, 2016 | 01:31 PM
GoThingNC's Avatar
GoThingNC
I will be replacing the Supercharger soon.
Original Waterpump was replaced at 75,000 miles and I am at 127,000 miles.
Should I go ahead and order a new WP and replace while I am in there?
Also, what would a used SC that needs a rebuild be worth?
Thanks !
Old Nov 23, 2016 | 02:30 PM
nkfry's Avatar
nkfry
Whether or not you replace the water pump would be up to you or if it is leaking. We don't see people back for another water pump once we replace it the first time, so I'd say you'll probably be fine with not replacing it.
We were buying cores for around $100-150 back when we needed to build inventory on chargers, but you may be able to find someone else who is in the rebuilding business to pick it up off of you.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 23, 2016 | 04:21 PM
GoThingNC's Avatar
GoThingNC
Thanks!
Old Nov 23, 2016 | 09:17 PM
Eric_Rowland's Avatar
Eric_Rowland
If it was replaced at 75K and you've got 57K on this one, I would replace. If you're doing the R&R yourself, it might be worth the risk, but it's a pretty big job should it fail. All depends on how many miles you put on it and plans on keeping it. But a new SC with a 57K? Not me.
Old Nov 23, 2016 | 09:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Whenever we replace the supercharger in our shop we always replace the water pump. It's too much work to skip on or have to do a short time later.
We do only use the original MINI pumps as we've had too many times we had to warranty aftermarket ones, and the original ones carry a 2yr warranty.
https://www.waymotorworks.com/r53-water-pump.html
Old Nov 26, 2016 | 01:05 PM
swiftycoop's Avatar
swiftycoop
Question, with the supercharger removed for oil service, should I mount the new WP to the SC and then hang it back on the engine or should I hang the SC and then install the new WP on the SC? Thanks for your help!
Old Nov 26, 2016 | 03:51 PM
WayMotorWorks
Vendor
We always install the water pump on the supercharger then put it all on as one part.
Old Nov 26, 2016 | 07:16 PM
swiftycoop's Avatar
swiftycoop
Thanks WMW, I'll follow your advise.
