R50/53 New mini owner. Supercharger pulley question.
What's up guys I went out about 2 weeks ago and bought a 2006 cooper S. I've done the Alta intake so far. Car is clean 62000 miles and a clean carfax with tons of maintenance.
I'm currently looking into buying a supercharger pulley. I'm seeing a few different brands and wanted to know which one is the better of them all. Looking at the 15% pulley.
Thanks in advance for the advice.
Alta makes a good one, Way Motor Works also makes a good one. As far as the size, the general consensus is that if you are going to take your car to the race track...go with a 15% pulley. If you are just going to be driving on the street, go with a 17%.
I went with a 17%....couldn't be happier.
For a street car that only sees short bursts of pedal to the floor moments....the 17% pulley is the way to go. You will have more boost on the top end, and it will come it at a lower rpm. All things that are great on the street
You only have heat issues if you are running high RPMS for long periods of time......like when you are driving on the track.
My car is a JCW, so it came with a JCW pulley on it....I think its close to a 14 % pulley, I could feel a boost in power going up to the 17%, but someone with a stock pulley will notice a much bigger gain than I did. You will be going from around 10psi of boost, to around 17psi......that makes for a healthy boost in power and torque. .....a new pulley is THE best power building mod for the money.
Awesome. Keep hearing it's the best mod bang for your buck. Guess it's true lol.
Yes I've seen a kit with pulley belt and plugs. That's how I'll order it. From wmw
https://www.waymotorworks.com/wmw-pulley-package.html
