Question re: replacing the green profile gasket
Old Nov 7, 2016 | 12:24 PM
JAB 67's Avatar
JAB 67
I need to replace the green profile gasket. This is item # 2 on the lower diagram on page 130-35 of the Bentley manual. I understand that in order to do so I need to remove the supercharger intake air duct, item # 3 on that same diagram. In order to remove that, is it necessary for me to remove the intercooler output air duct, item # 5 on the lower diagram on Bentley page 130-34? TIA.
Old Nov 7, 2016 | 02:15 PM
nkfry's Avatar
nkfry
You will need to remove the intercooler, BPV intake horn, throttle body, brake booster vacuum source, MAP lead, and the black intake duct to replace the gasket.
Not a hard job, all in all we have them replaced in about an hour with a hoist and given skill set. Just make sure that the surfaces are clean and that the intercooler boots don't get tucked or improperly seated and you'll be fine.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 7, 2016 | 03:20 PM
JAB 67's Avatar
JAB 67
already came to that conclusion and it has now been removed.
