R56 Need mini mechanic in jax, fl
Old Nov 6, 2016 | 12:22 PM
cblackmar's Avatar
cblackmar
I tried to replace turbo oil line but can't get to it all. I know my limitations! Any mechanics to choose from for help in Jacksonville Florida area?
Old Nov 6, 2016 | 12:59 PM
Capt_bj's Avatar
Capt_bj
Jacksonville area mini motorers (JAMM) is a group on facebook
(a closed group)
you could join and ask there ....
sadly few folks use the once popular and useful SunshineMinis.org web site ... where this type of info was easily found ...
Sunshine Minis is an open group on FB, you could ask there too.
Old Nov 6, 2016 | 01:05 PM
cblackmar's Avatar
cblackmar
Not on Facebook
Old Nov 6, 2016 | 01:15 PM
Capt_bj's Avatar
Capt_bj
well, like I said, that's where the folks have moved that discuss your topic
I think websites were more useful in this case but I'm in the minority.
try here - dunno how current the info is
http://www.sunshineminis.org/forums/...p?f=10&t=24840
they mention this guy but reference a dead link ...
http://automotive-industries.com/
Old Nov 6, 2016 | 01:26 PM
cblackmar's Avatar
cblackmar
Found the list on administrator. Thx for info. I think my issue is right tools to get heat screens off.
Old Nov 6, 2016 | 03:07 PM
Fly'n Brick's Avatar
Fly'n Brick
This any help?
http://www.minirepairshops.com/searc...ksonville%20fl
Old Nov 7, 2016 | 04:18 PM
cblackmar's Avatar
cblackmar
I got the oil line changed by myself, right tools help! What I would like some advice on is an oil leak. right in front of the turbo oil line where it comes from the block there is a piece the has a few 8mm bolts holding it on. I am not sure what it is, but there is a silver hose that goes out the top of it to the bottom of the turbo. Right at the base of that it leaks. It's not much but enough that when the block gets hot is burns, then the radiator fan catches the smoke and sends it out the air scoop. Big question, is this ok?
Old Nov 10, 2016 | 10:35 AM
MiniToBe's Avatar
MiniToBe
are you referring to bolt number 12 in the image below?
http://www.realoem.com/bmw/enUS/show...diagId=11_3944
Old Nov 11, 2016 | 05:38 PM
cblackmar's Avatar
cblackmar
Found out it is oil filter housing. The gasket is going and the seep hole is seeping.
