R60 215/60r17
Old Nov 1, 2016 | 10:23 AM
acer_ace's Avatar
acer_ace
Exclamation 215/60r17
Let me start off by apologizing if this has been covered. I did a search and read through many pages and could not come up with a conclusion. If you have a link to where this is covered please let me know.
I have a 2012 Countryman S. I would like to go bigger tires without the lift. So far, from my research, 215/55R17 seems to be the biggest I can go.
Has anyone tried 215/60R17? I also came across a thread where they said 27" is the biggest diameter you would want to go, but curious if can go .2 higher.
215/55R17 --> 26.3" high / 8.5" wide
215/60R17 --> 27.2" high / 8.5" wide
205/60R17 --> 26.7" high / 8.1" wide
As stated, I have read about using the 215/55R17, has anyone tried the other two sizes?
Ace - Houston
Old Nov 3, 2016 | 09:34 AM
bmwr606's Avatar
bmwr606
i run 225/50R18s on my cms all4, up sized from 225/45R18
225/50 is 26.9 inch OD
225/45 is 25.9 inch OD
for winter i run 205/70R16 on mini oem 16x6.5 et 46 alloys
205/70 is 27.3 inch OD
hope this helps
Old Nov 3, 2016 | 09:45 AM
acer_ace's Avatar
acer_ace
Thank You.
I was curious about 225, but seemed a bit wide. If you have no rubbing issues, I am now considering 225/55/17 which would put me at 26.7 high" but 8.9" wide.
Would you happen to have any pictures? Curious how the 225's look.
--Ace
Old Nov 3, 2016 | 09:55 AM
bmwr606's Avatar
bmwr606
left to right
225/50R18
205/70R16
225/45R18
no rubbing at all, been running the larger sizes over 4 years now
Attached Thumbnails 215/60r17-1406536470793.jpg   215/60r17-100_1918.jpg   215/60r17-100_1789.jpg.jpeg
Old Nov 3, 2016 | 09:59 AM
bmwr606's Avatar
bmwr606
just found there closeups ... thiught i had deleted them
205/70R16 and 225/50R18
Attached Thumbnails 215/60r17-100_1920.jpg   215/60r17-100_1922.jpg   215/60r17-20140420_132145.jpg   215/60r17-20140420_132130.jpg
Old Nov 3, 2016 | 10:21 AM
acer_ace's Avatar
acer_ace
Right on.. Thank you, appreciate you taking time and answering my concerns.
Old Nov 3, 2016 | 01:40 PM
Euler-Spiral's Avatar
Euler-Spiral
sizes can be within 10%,,,,of ratios,,,,,, rim width changes size,,, some specs give actual size in a specific rim. if not and you are close ask the sales rep
Old Nov 3, 2016 | 02:31 PM
acer_ace's Avatar
acer_ace
Not following...
Old Nov 3, 2016 | 03:04 PM
Euler-Spiral
the aspect ratio on the side of the tire isnt the actual size but will be within 10% so a smallish 205 may be about the same as a large 195. some specs show the actual size on a rim. Then a 205 on a 6in rim will be a bit smaller than on a 7.5in rim as the sidewall spreads a bit more, also some specs will give the contact patch width and the overall width. some 205's will be wider but have a small contact patch. just to go all out there are some specs for rolling raduis or revs per mile that can sometimes help understand sidewall stiffness
