R55 Need a photo of rear door seal between glass
Old Oct 31, 2016 | 09:08 AM
MiniClubbie's Avatar
MiniClubbie
Dear Friends,
Can any one take a close-up photo of the spcae between left and right rear door glass when both doors are closed? My weatherstrip is a bit deformed and part of it goes fully under right doors and part over it. I would like to know what the correct position should be.
Thank you!
Old Oct 31, 2016 | 09:14 AM
pkunk's Avatar
pkunk
from inside or out?
Old Oct 31, 2016 | 09:15 AM
MiniClubbie
outside please
Old Oct 31, 2016 | 09:33 AM
pkunk's Avatar
pkunk
Originally Posted by miniclubbie
outside please
A little dusty and full of reflections, but is that what you need?
Old Oct 31, 2016 | 10:03 AM
MiniClubbie
not exactly. I took the picture of mine. As you can see the lower part of weatherstrip is on the right door and upper is being completely pressed. What is correct?
Old Oct 31, 2016 | 07:52 PM
pkunk's Avatar
pkunk
Your's looks f&%ked up. The right door is supposed to compress the weatherstrip that is on the left door evenly all the way
Old Oct 31, 2016 | 11:34 PM
MiniClubbie
Yes, but what is the correct alignment? Lower or upper?
Old Nov 1, 2016 | 10:04 AM
bugeye1031's Avatar
bugeye1031
Moderator
I have the same question....I believe the upper portion is correct
Old Nov 5, 2016 | 07:15 PM
pkunk's Avatar
pkunk
The upper portion.
Old Nov 5, 2016 | 11:59 PM
MiniClubbie
ok, thanks Guys. Now it is time fiddle with this weather strip
