R56 Base Cooper doesn't think I filled up the tank
Old Oct 30, 2016 | 11:54 AM
kyoo's Avatar
kyoo
I'm not sure if it's an issue with the floater or what but after I filled up the gas the gauge still thinks the car is empty. The distance to empty keeps shrinking. Not sure what triggered this, if it's the floater or what but the pump fills up and stops accurately.
Old Nov 3, 2016 | 12:18 AM
CH2iS's Avatar
CH2iS
It sounds like a failing sending unit. The link provided shows you how to get to the sending unit and replacing it. Hope this helps
http://www.pelicanparts.com/techarti...eplacement.htm
Old Nov 30, 2016 | 08:39 AM
kyoo's Avatar
kyoo
To be clarify - I think the floater was just stuck in the tank somewhere.
However, since then, I'm getting a recurring P0463 code, fuel level sensor circuit code?
https://www.obd-codes.com/p0463
