R56 R56 MCS Engine Toque Specs
Old Oct 28, 2016 | 09:32 AM
Stokersrule's Avatar
Stokersrule
I’m looking for torque specs for the N14 engine. Is there a comprehensive listing anywhere? I can’t seem to find one anywhere on the internet. I’ve come across some and entered them below but can't find a good reference which lists them all.
Cylinder Head Bolts:
Intake Camshaft Sprocket Bolt: 20NM +180 deg
Exhaust Camshaft Sprocket Bolt: 20NM + 90 deg
Bolts to Attach upper & lower block sections:
Oil Pump drive sprocket bolt:
Connecting Rod Bearing Cap Bolts:
Camshaft bearing cap bolts:
Crankshaft Dampener Bolt: 50NM + 180 deg
I believe that the head bolts, cam sprocket bolts and oil pump sprocket bolt are TTY and should be replaced at every use.
Are there any other critical torques I might need?
Old Oct 28, 2016 | 10:14 AM
Euler-Spiral's Avatar
Euler-Spiral
Haynes online has charts they are in a couple of spots it took me a bit to find them all, they also have some tips that differ from the Bently so its worth it. If I remember correctly the shoulder bolts that locate the timing guide are too high I use a standard metric torque number you can find a chart on line. Be careful with the surfaces of the timing cams and crank shaft sprockets I clean them with alcohol just before so there is no residue
Old Oct 28, 2016 | 02:43 PM
nkfry's Avatar
nkfry
Bentley Manual
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Oct 25, 2024 | 03:19 PM
outlawspeeder's Avatar
outlawspeeder
Originally Posted by nkfry
NOT IN THAT BOOK AND IT SUCK don't waste your money if you are going past the valve cover.
danraabe
Apr 13, 2021 07:15 PM
Mini Chilli
Mar 25, 2021 01:23 PM
mini907
Apr 6, 2019 05:44 PM
silence2-38554
Oct 14, 2015 10:08 AM
jlm
Oct 27, 2004 04:17 AM
