R56 Scan Gauge 2 / Boost
Old Oct 27, 2016 | 09:15 PM
D1QuickSilver's Avatar
D1QuickSilver
I have a Scan Gauge with the MINI software.
At idle it's showing a negative number, is it normal? If it's normal, what numbers should I be seeing for this vacuum?
I can't drive right now so I can't tell if it'll display positive boost.
Thanks.
Old Oct 28, 2016 | 03:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
That's normal.
Old Dec 6, 2021 | 08:41 AM
HarryEngine's Avatar
HarryEngine
I had a problem with the bouquet due to a malfunctioning radiator. An intercooler has two main functions of lowering the temperature of the incoming air and decreasing the boost pressure. The pressure is reduced by the flow resistance of the intercooler. This, in turn, causes some limitations in the design, since a pressure drop of more than 1-2 psi is unacceptable. The pressure did not decrease, which caused the loss of boost, I looked options for 5.9 Cummins Intercooler Upgrade for my Dodge Banks 25980 Techni-Cooler Intercooler System is good radiator for my car
frankiev
Dec 10, 2021 06:21 AM
Mtb Awesome
Oct 9, 2021 06:49 PM
johntotah94
Jun 10, 2019 03:32 PM
chikmagnet
Nov 4, 2005 11:13 AM
synergy1
Jul 25, 2005 02:10 PM
