JCW OEM Factory Maintenance .......
I have to plan ahead of time for scheduled maintenance because going to Seattle is time consuming. I will be at about 27K and it will be time for the 10K oil change.
In same time, they have some trim parts to install from my previous visit going back 7 months ago and I am aware they will need several days.
I am wondering what are the inspections that will be performed and if there is anything not covered. This will be the 3rd service from new.
I am still under the 3y/36K until July 2017.
Today, I checked the engine oil for the 1st time in 6 months. No need to top up and it is clean. It is about 7.5K since the last oil change.
It was just about time to take a look and see.
Independent shops don't have key readers. They have to rely on some information source to know what to inspect and replace. Again, where is it coming from?
I asked the same question many times.
Since most Mini owners don't seem to go to the dealership for maintenance and many are doing their own, the data and specs have to come from somewhere.
It has always amazed me that nobody and even the vendors here have no answer.
you change what needs changing. everything else is preventative maintenance. if you have 30k miles i'd suggest changing at least the spark plugs (esp since you have the JB+). your thermostat and water pump may be on their last legs so you can change those out too if you have time/money. while you're at it, change the water pump friction wheel and the water pump tube. other than that, motor on!!! :D
This is what I've got so far from the dealer in my country:
Note: all service were done annually (time based) and not on mileage basis.
1st service: oil, oil filter, wiper blades, wiper fluid concentrate.
2nd service: oil, oil filter, wiper blades, wiper fluid concentrate, air filter, cabin filter.
3rd service coming up: same as 1st service plus brake fluid change.
So if you're doing your third service it would just be normal oil change plus the brake fluid change if it's already 36 months old. Dealer didn't mention any special inspections unlike my previous BMWs.
Just like you said no need to worry about oil level too much, the DME is so smart it would tell you when the oil is low, plus the B48/46 doesn't seem to burn much oil at all.
Absolutely not true....please do not count on your car to tell you that your oil level is low. The warning only kicks in when your oil pressure is low and by then your oil level is more than a quart low. This is true of the F-chassis cars as well. The new engines aren't as thirsty as the 2nd gen engines, but I have had to put in about 2 quarts over 3 times in the last 17k miles. CHECK YOUR OIL AND CHECK IT OFTEN!
I looked at the previous service tickets and they also replaced spark plugs every time but never the cabin filter.
Does anybody know what is the standard inspection check list when you go for service and do you have a print out?
I never received anything.
