Question???
Old Sep 17, 2004 | 08:48 AM
Chobe's Avatar
Chobe
Question???
I Would like to know if its a good idea to use a fuel injector cleaner, the ones that you get a gas station and that you put in with a full tank of gas.
Old Sep 17, 2004 | 09:08 AM
Trippy's Avatar
Trippy
I'm going to say you do NOT need to add any fuel additives.
The CarTalk guys say not for modern cars using modern gas with detergent.
The simple answer is no, you don't have to use a fuel injector cleaner.
CarTalk_0
I don't think any special fuel injector cleaning is necessary unless your injectors are giving you problems.
CarTalk_1
Autodoc says no.
I do not sell or use any fuel-injector cleaner, nor do I recommend using it.
Auto Doc
STP (Manufacturer of cleaners) says yes.
Just as brushing your teeth keeps harmful bacteria from building up on your teeth, STP® Gas Treatment and Fuel Injector & Carburetor Cleaner help keep harmful deposits from building up in your engine's fuel intake system, including fuel injectors and carburetors. It is important to keep your fuel system free of deposits in order to maintain maximum performance. These STP® products do not remove existing deposits.
STP website
Valvoline (Manufacturer of fuel additives) says yes.
Improves acceleration, restores lost power and eliminates rough idle and hesitation
Valvoline
Old Sep 17, 2004 | 09:37 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I've been searching around and found alot of opinions. Overall it looks like it doesn't really make much measurable difference.
There are several concerns. First- does it work at all. Maybe. Does it do any harm- probably not. If you use premium gas you are supposed to get some additives that help to keep your fuel injectors cleaner but it will vary with your brand of gasoline.
Second, in order for it to work do you use it intermittently like once in awhile (it does active cleaning like Valvoline claims) or it prevents trouble so you need to use it all the time to keep the fuel injector cleaner. If it prevents problems then you'd need to use it alot and by the time you add up your bill over 6 to 12 months you might has well have a fuel injector servicing done by your mechanic or shop since that would be a better cleaning.
Personally if you have a newer car I don't think it makes any difference to use the additive. I don't think you can tell the difference. No independent long term tests have been done to check the benefit or harm done on fuel injectors by using additives on a regular basis. Since the benefit is unknown then companies that make the products can suggest in advertising that a potential benefit exists and that is why you should use their product.
If it were really true that you would benefit then your car manufacturer would include it as part of your maintenance and servicings.
Old Sep 17, 2004 | 11:03 AM
ElonCooper's Avatar
ElonCooper
I understand you folks are addressing fuel injector cleaner only, but their are really good products like BG 44K that also address possible build up in intake ports and valves, and deposits in the combustion chamber. Doesn't hurt to play it safe every 10,000 miles or so to drop a can of that in. If these cars run pig rich as some have commented, seem like such build up could be possible. Just a thought.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
