whats this from the gearbox ? (oil leak from there)
Old Oct 12, 2016 | 09:14 PM
Alan Clavero's Avatar
Alan Clavero
Hi, i have a mini cooper r56 2008 and I have a small leak from this part ... whats this ? how do I change it?
Thanks !
Old Oct 13, 2016 | 03:54 PM
oldbrokenwind's Avatar
oldbrokenwind
Thanks !
That's called a "blind plug", and there should be another one alongside of it. Underneath it is one of the bolts holding a crankshaft bearing in place. Removing it is a destructive process and it should be replaced, but only if you're sure that's where your leak originates. You don't want to tweak the bolt, just apply liberal sealant around the new plug --- not too much --- you don't want sealant on the bolt, just on the plug's lip.
Oh yea --- removing it --- I used an old, sharp screwdriver to wedge between the plug and block, then twisted the screwdriver --- it's not threaded. No need to drain oil, as the level is below these plugs. Mine is all over the garage so removing it was relatively easy. Part number is available on RealOEM but it's probably a dealer only item --- one of the less expensive parts, maybe a couple bucks.
Old Oct 14, 2016 | 07:21 AM
Alan Clavero
Thanks very much ! I bought these plugs , i'll change them later.
andrewjg1994
Sep 3, 2018 08:16 AM
Kristopher Sullivan
Tires, Wheels, & Brakes
12
Jan 10, 2017 07:33 PM
Nicbay350
Aug 10, 2016 08:18 AM
dorkfaceandrew
Aug 10, 2016 01:41 AM
APDspider
Aug 7, 2016 07:59 PM
