How to Erase Codes?
Old Oct 10, 2016 | 12:52 PM
thebombardier's Avatar
thebombardier
How to Erase Codes?
So I have literally never been able to erase codes on my Mini. Bluetooth scanner, WiFi scanner, even a $100 HFT scanner. I hit "Erase Codes" and it says "cannot connect" or something along those lines. I can read codes no problem though. The HFT scanner says "turn engine off with key on" tired with the car in accessory mode, still no dice. What am I doing wrong? Do I need a special BMW scanner or something?
Old Oct 10, 2016 | 01:33 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I was able to erase codes with either my old plug in OBD scanner Actron brand or with a free app on my phone and a cheap Amazon plug in OBD dongle. This was a 2011 S Countryman. Only code that would not go would be one that is still faulting. Neither of those devices would see the MINI specific codes that need a dealer or qualified indy shop reader to see.
So what kind of codes are showing that wont go?
Old Oct 10, 2016 | 01:36 PM
thebombardier
O2 Heater Sensor 2 (or whatever one you get with a catless DP). Not a MINI specific code but I had my tune turned off for a bit and it came up. Turned my tune back on and drove 30 miles, didn't go away. Trying to turn it off with my scanner.
Old Oct 10, 2016 | 02:02 PM
Minnie.the.Moocher
Mario would be the guy to answer that.
Old Oct 10, 2016 | 04:00 PM
thebombardier
I actually figured it out. Turns out when you turn the engine off you're not in accessory mode. Accessory mode is key in, press engine start but don't press the clutch.
But not 2 of my monitors aren't ready and I need an inspection lol. NY allows one not ready, and the other one besides O2 not ready is Evap, which should go away in a few drive cycles or when I fill up/
Old Oct 10, 2016 | 04:02 PM
oldbrokenwind's Avatar
oldbrokenwind
Try disconnecting the battery for a minute or so --- negative terminal. That's supposed to clear codes that don't recur. Disadvantage is, you gotta reset the clock and maybe radio stations too.
7mgte
Oct 16, 2023 06:12 AM
spearmin
Tires, Wheels, & Brakes
11
Oct 26, 2016 12:40 AM
haxmed
Sep 16, 2016 03:45 PM
SneedSpeed
Sep 12, 2016 06:52 AM
NEPABob
Sep 10, 2016 04:16 PM
