2009 R55 Foot Well Module Wiring help
Old Oct 9, 2016 | 10:27 AM
Tim McCreary's Avatar
Tim McCreary
Hi everyone,
I recently purchased a 2009 Mini Cooper Clubman and am fixing it up for my daughter (overheated, replaced water pump, pipe, and thermostat housing). Got just about everything working and my driver's side reverse light is not working. Got power to the passenger side, but no power at the socket or wire (blue-gray) on the driver's side. Ground on driver's side is good and the other lights in the assembly work fine.
I have a Haynes Manual and it shows two different wires coming from the Foot Well Module to the left and right lights.
I need to see if there is power coming out of the module, meaning a broken wire on down the line. There are several blue-gray wires and I want to only pierce one wire.
Does anyone have a picture of the pin-out and/or wiring diagram showing the location for the passenger backup light?
Any help would be appreciated.
Old Oct 10, 2016 | 10:14 AM
Tim McCreary
Anyone?
Looking for the wiring diagram for X14260 and X14261 connector, specifically the blue-gray wires going to the reverse light bulb. I need to know which connector and wire position goes to the driver's reverse light.
Thanks,
Tim
Old Oct 17, 2016 | 12:36 PM
Tim McCreary
Ok, apparently smelling too many exhaust fumes. I thought there was a clear lens in the left tail light and there is not one.
With this said, does anyone know what pin the driver's rear fog light is coming out of the footwell module? A different BMW footwell diagram is showing wire #47. Just making sure. Probably buying a European taillight with the clear backup lens and want to splice it at the footwell.
Thanks!!
Tim
Old Oct 17, 2016 | 05:24 PM
MiniToBe's Avatar
MiniToBe
im looking through my wiring diagrams here what i got for you
here is what i have for the three connectors of the FRM.
A4011 Footwell module
Connector overview
Number X-pin, color Description X14259 26-pin, black Component connector Footwell module X14260 51-pin, black Component connector Footwell module X14261 51-pin, black Component connector Footwell module Pin assignments at plug connector X14259
Pin Type Description / Signal type Connection /
Measuring notes 1 E Signal, front side marker light Steering column switch cluster 2 E Signal, low beam switch Steering column switch cluster 3 E Signal, left direction indicator light Steering column switch cluster 4 E Signal, right direction indicator light Steering column switch cluster 5 Not occupied 6 Not occupied 7 Not occupied 8 E Signal, headlight beam height control Steering column switch cluster 9 Not occupied 10 Not occupied 11 Not occupied 12 A Supply, interior lights Footwell light, front left Footwell light, front right 13 Not occupied 14 Not occupied 15 Not occupied 16 E Signal, high beam/headlight flasher switch Steering column switch cluster 17 Not occupied 18 E Signal, hazard warning switch Hazard warning switch 19 Not occupied 20 A Signal, LED hazard flasher switch Hazard warning switch 21 A Signal, terminal 58G Connector, instrument and locator lighting 22 Not occupied 23 Not occupied 24 Not occupied 25 Not occupied 26 Not occupied Pin assignments at plug connector X14260
Measuring notes 1 Not occupied 2 E Terminal 30 Fuse F48 3 A Signal, fog light Side marker/fog light, right 4 A Signal, high beam Right headlight 5 Not occupied 6 A Signal, low beam Left headlight 7 Not occupied 8 A Signal, parking light Side marker/fog light, right 9 A Signal, reversing light Taillight, right 10 A COOPER S LHD Signal, rear fog light Rear fog light, right 11 A Signal, right auxiliary direction indicator light Direction indicator light repeater, front right 12 A Rear right direction indicator Taillight, right 13 A Signal, front left direction indicator Left headlight 14 A Signal, parking light Taillight, left 15 A Signal, headlight beam height control Left headlight 16 A USA Signal, parking light Side marker light, front left Side marker light, rear right 17 A Signal, headlight beam height control Left headlight 18 A USA Signal, parking light Side marker light, front right Side marker light, rear left 19 A Signal, headlight beam height control Left headlight 20 Not occupied 21 Not occupied 22 Not occupied 23 Not occupied 24 Not occupied 25 Not occupied 26 M with dynamic headlight range adjustment Ground Ride height sensor, front Ride height sensor, front 27 M with dynamic headlight range adjustment Ground Ride height sensor, rear Ride height sensor, rear 28 A Signal, headlight beam height control Right headlight 29 A with dynamic headlight range adjustment Supply, level sensor Ride height sensor, rear 30 A Signal, headlight beam height control Right headlight 31 A with dynamic headlight range adjustment Supply, level sensor Ride height sensor, front 32 A Signal, headlight beam height control Right headlight 33 Not occupied 34 Not occupied 35 A Interior lights without lights package Interior light, rear 35 A Interior lights light package Roof operating unit 36 Not occupied 37 Not occupied 38 Not occupied 39 Not occupied 40 A Signal, center brake light Auxiliary brake light 41 A Activation, bi-xenon shutters Left headlight Right headlight 42 Not occupied 43 Not occupied 44 Not occupied 45 A/E CAN bus low CAN-bus connector 46 A/E Signal, start lock switch CAN-bus connector 47 M Ground Ground point 48 E with dynamic headlight range adjustment Signal, rear level sensor Ride height sensor, rear 49 E with dynamic headlight range adjustment Signal, front level sensor Ride height sensor, front 50 A Signal, headlight beam height control Left headlight 51 A Signal, headlight beam height control Right headlight Pin assignments at plug connector X14261
Measuring notes 1 E Terminal 30 Fuse F5 2 Not occupied 3 E Terminal 30 Fuse F8 4 A Signal, driver's power window motor, closed Driver's window motor 5 A Signal, driver's power window motor, open Driver's window motor 6 A Signal, high beam Left headlight 7 Not occupied 8 E Signal, switch lighting orange Roof operating unit Ambient lighting, left B-pillar Ambient lighting, right B-pillar 9 A Right brake light Taillight, right 10 Not occupied 11 Not occupied 12 E Supply, terminal 15 A149a Car access system 13 E Door contact signal System lock, passenger's door 14 Not occupied 15 E Door contact signal Clubdoor lock, top 16 Not occupied 17 Not occupied 18 M Ground Ground point 19 E Reversing signal Reversing light switch 20 Not occupied 21 E Brake light switch signal Brake light switch 22 Not occupied 23 Not occupied 24 E Door contact signal System lock, driver's door 25 Not occupied 26 E Door contact signal Clubdoor lock, bottom 27 E Signal, interior light switch Roof operating unit 28 M Ground Ground point 29 Not occupied 30 E Signal, switch lighting Roof operating unit 31 Not occupied 32 E Signal, switch lighting blue Roof operating unit Ambient lighting, left B-pillar Ambient lighting, right B-pillar 33 M Ground Ground point 34 E Terminal 30 Fuse F47 35 A Signal, front passenger's power window motor, closed Passenger's window motor 36 A Signal, front passenger's power window motor, open Passenger's window motor 37 A Signal, fog light Side marker/fog light, left 38 A Signal, low beam Right headlight 39 Not occupied 40 A Signal, front right direction indicator Right headlight 41 A Signal, parking light Taillight, right 42 E Signal, lock central locking System lock, driver's door 43 A Rear left direction indicator Taillight, left 44 A Signal, left auxiliary direction indicator light Direction indicator light repeater, front left 45 A Rear left direction indicator Taillight, left 46 E Signal, unlock central locking System lock, driver's door 47 A Signal, reversing light Taillight, left 48 A Signal, terminal 58G Connector, instrument and locator lighting 49 A Signal, licence plate light Trunk lid push-button/license plate lights 50 A Signal, parking light Side marker/fog light, left 51 A not COOPER S LHD Signal, rear fog light Rear fog light 51 A COOPER S LHD Signal, rear fog light Rear fog light, left
Old Oct 17, 2016 | 06:02 PM
Tim McCreary
Thanks!!!! This will help very much with troubleshooting!
Tim
Old Oct 17, 2016 | 06:08 PM
MiniToBe's Avatar
MiniToBe
glad to help
Old Feb 17, 2019 | 11:01 AM
guspi76's Avatar
guspi76
Originally Posted by Tim McCreary
Hi everyone,
Clubman's only have one reverse light.
Kristopher Sullivan
Tires, Wheels, & Brakes
12
Jan 10, 2017 07:33 PM
mc40#822
Aug 12, 2016 04:57 PM
APDspider
Aug 7, 2016 07:59 PM
Cadbury_R55
Aug 6, 2016 12:23 PM
InnocentiMini
Aug 3, 2016 04:52 PM
