Headlight auto level fail
Old Oct 7, 2016 | 10:24 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
My headlights wont auto level high enough, and the height adjusters are already max
They auto adjust down and grumble like they are trying to lower even more before they go up but not up enough
here's a vid showing the problem
I unhooked the level sensors and both of them do make the headlights move up and down, but no higher than they will auto level themselves, and it's too low.
any ideas? It's almost like they slipped on the threads inside whatever does the adjusting, both sides sound/operate identically
Old Oct 7, 2016 | 01:58 PM
RB-MINI's Avatar
RB-MINI
Are they face lift Xenons? If so, are the ball and sockets still connected inside the headlight housings? They can pop loose from big bumps, or from shutting the hood too hard.
Old Oct 7, 2016 | 02:25 PM
MrBlah's Avatar
MrBlah
facelift, I can grab the housing inside and they feel connected, not loose
Old Oct 12, 2016 | 01:11 PM
All I can think of is that one of the rear level sensor are bad or maybe the bracket that holds them ?
Are the brackets bent and did you move the sensor by hand ?
Old Oct 12, 2016 | 01:29 PM
MrBlah's Avatar
MrBlah
Unhooked then, moving by hand they adjust the light but not high enough
Old Oct 12, 2016 | 01:46 PM
You did this to the front sensor also? So you have to move the front one down and the rear one up to get to the max height.
Old Oct 16, 2016 | 05:29 PM
MrBlah's Avatar
MrBlah
yeah to both, I put the car up on the lift and unhooked them, verified they both work and independently raise/lower light
I tried maxing them both out in both directions, they wont adjust higher than the video, and when they auto adjust when powered up they make a grinding sound
Old Oct 19, 2016 | 09:22 AM
MrBlah's Avatar
MrBlah
verified the adjuster socket things are all connected. I gave up on a fix, cut some wood inserts into the high beam cover, they push up the headlights where they should be. They hold the light at a minimum height, and I can use the external adjusters to tweak
Auto level sucks anyway, only fast enough to be irritating
bugeye1031
R55 :: Clubman Talk (2008+)
Sep 20, 2016 07:02 PM
anotherminiinthegarage
Sep 19, 2016 12:15 PM
willc23
Sep 17, 2016 04:01 AM
haxmed
Sep 16, 2016 03:45 PM
Sugeray
Sep 13, 2016 07:02 PM
