Whirring - fuel pump? Normal?
Old Oct 6, 2016 | 07:43 PM
blue2's Avatar
blue2
I hear a whirring in the area of my right rear wheel well occasionally (2013 Clubman, non-S). I notice it when I return home in the evening, it's very infrequent. From my research of other posts it sounds like it's the fuel pump but what I haven't learned from any of the posts is if this is normal or if it's something that is going to need to be fixed.
Can anyone advise me on this? I'm just about at 48,500 miles so am close to being out of warranty.
Thanks in advance!
Old Oct 12, 2016 | 12:50 PM
The rear pump will make some noise, what it does with the newer HPFP is prime itself when you open the door or unlock the car, its a short whirl then it stops.
If its the right rear it could also be normal from the leak Diagnosis pump which works with the EVAP system for gas tank fumes and pressure.
RochelleP
Aug 24, 2016 12:50 PM
mayfield1
Aug 17, 2016 11:48 AM
Gen1
Aug 13, 2016 06:40 PM
spikeyadrian
Aug 12, 2016 07:47 AM
pfcmooney
Suspension
Aug 8, 2016 05:49 PM
