Drivetrain turbo smart Kompack shortie??
Old Sep 25, 2016 | 04:15 PM
BigBoost's Avatar
BigBoost
Any one running the dual port BOV !
Ran a crossed it on ECS
seen lohen uk has it up on there site
just wondering if anybody had any experience with it!!
https://www.ecstuning.com/Mini-2007-...lve/ES3154056/
Old Sep 27, 2016 | 09:31 AM
BackcountrySkier13_inAZ's Avatar
im interested to know more about it myslef
Old Sep 27, 2016 | 10:03 AM
BigBoost's Avatar
BigBoost
i got a hold of lohen ' and emma saying they are saling like crazy ! I like the idea of it being mechanical controlled! compared to electrical / solenoid like the forge vavle i ended up ordering it up keep and eye out' ill be doing some kind of little write up on it
Old Sep 27, 2016 | 10:11 AM
Very cool!
Old Sep 27, 2016 | 02:06 PM
Just added those to the site, you found them very fast
Old Sep 27, 2016 | 04:17 PM
BigBoost's Avatar
BigBoost
yeah I try to keep up as much as possible with the performance aspects with the n14's !!
i'm currently running the forge atmosphere bov ' and it's really starting to get annoying every time you let off it blows off! even when your cruising around with low throttle response
I really like the idea of the turbo smart valve being mechanical / vacuum- actuated instead of a solenoid / ecm!
and the highbred 50-50 I'm really not sure why Forge didn't do it in the beginning! especially being that it's Map driven!! who know!!!s butt new things are allway's fun
Old Sep 27, 2016 | 08:38 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
I have a shorty 50/50 for an EFR 6258 turbo sitting in the garage we used for testing. Outstanding unit and never triggered a CEL on the N14, but do pay attention to the adjustment procedures. The boost pressure in the manifold helps hold the valve closed so it is not necessary nor recommended to tighten it too far when installing it. Assuming more is better and cranking it all the way in can result in compressor surge.
Old Sep 28, 2016 | 01:54 PM
Nice.
Old Sep 28, 2016 | 02:23 PM
MarioKart's Avatar
MarioKart
Vendor
Is this for only the N14 motor or N18 also?
mQubed Motorsport, Manic Tuning Dealer
Old Sep 28, 2016 | 02:41 PM
They state for both engines N14 and N18.
Also there is the plumb back version:
https://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Engine/Turbocharger/Blow_Off_Valve/ES3154060/
Old Sep 28, 2016 | 04:58 PM
BigBoost's Avatar
BigBoost
who doesn't like sounding like a rally car! chirp chirp'
And when i talk with emma from lohen' she was saying it will work for both the n14 & n18's
how difficult is it to find a Settings on the vavle? or is it going to be few hours worth of trial and air!?
how's the sound? i was trying to find video's but no luck was only able to find it on the ford st & and speed 3'
there's not much about it on the net ' yet.. was going try to write up a little review on it when o get it!
Old Sep 29, 2016 | 10:22 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
If it's like the EFR version it is not necessary to drive it to set it. It can be adjusted by revving the engine and listening to the sound. There should be a micro-CD in the package with a video and instructions.
Unfortunately, I cannot personally confirm proper operation on the N18. Pneumatic recirc valves like the Alta were found to not work well on the N18 since there is considerably less manifold vacuum off throttle than on the N14. However, since the unit is adjustable there may be a happy middle ground on spring tension that works well.
Old Nov 16, 2016 | 05:51 AM
mikeBURRITO's Avatar
mikeBURRITO
Is there any benefit to having vacuum controlled vs ecu controlled? I know the computer is pretty good at getting power up. Does anyone have any reviews of this yet? Like boost said. My Forge bov is getting annoying and am thinking about selling it.
Old Nov 20, 2016 | 05:58 AM
jetsr6's Avatar
jetsr6
I have the Kompack Dual Port and I like it. Its adjustable so if you get your turn boost turned up it will hold tighter and not leak through. The Dual port opens to the recirculater side first then to atmosphere. Works off vacuum and has some sort of resister connecter(I'm assuming), to engine harness to not through codes. I haven't had any codes for it.
I like it.
Old Nov 20, 2016 | 01:33 PM
BigBoost's Avatar
BigBoost
I like it.
I've been getting PM asking to post a video' but I've got mine put away for the winter' you should get a video ' and post it here'
Old Nov 20, 2016 | 02:04 PM
jetsr6's Avatar
jetsr6
Well I mite be able too but it won't be anytime soon. Going 5 states away for Thanksgiving for a week and have long work days. Plus I'm not a good video taker.
Old Nov 20, 2016 | 05:00 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It will be interesting to see if they actually work on the US spec cars. Since it vents to atmosphere the ECU may still throw a check engine light or go into limp mode. This is what we've seen in the past with other spacers or valves that vent to atmosphere.
The UK cars work better with it since their programming is different as their N14 cars don't even have MAFs. So that is likely why they like them.
We've been using the Forge Recirc valves as they are mechanical valves that are vacuum controlled so they hold more pressure and react faster. But since they still recirculate the boost they don't throw a check engine light.
https://www.waymotorworks.com/forge-blow-off-valve.html
Old Nov 20, 2016 | 05:10 PM
mikeBURRITO
I have actually been using the Forge atmospheric bov for about a year and no CEL. I am interested because the sound is getting a bit annoying. if you install everything right, there shouldn't be any problems. another thing that peaks my interest is that the turbosmart is adjustable and i would like just a little flutter.you know, just a little under high boost.
Old Nov 20, 2016 | 05:20 PM
WayMotorWorks
Vendor
I agree I never liked the Psssh sound from the vent to atmosphere valve. It's good that you haven't had a light. Not all cars get a light but more than half so we warn customers so they don't get upset at us.
We do offer the TurboSmart Valve too if someone wants it.
https://www.waymotorworks.com/turbos...bov-valve.html
Old Nov 20, 2016 | 06:47 PM
BigBoost's Avatar
BigBoost
i know the Subaru guys really like the 50/50 valve ' getting the best of both world's' maybe they'll catch on'
You Would think manic would be able to tune that out'
Old Nov 20, 2016 | 06:50 PM
BigBoost's Avatar
BigBoost
Do you have them in stock or is it a direct ship' i'm working an a buddies car and he's wanting to get one' and he's also talking about getting the manifold from you guy's'
Old Nov 21, 2016 | 06:54 PM
WayMotorWorks
Vendor
Yes we have it ready to ship as soon as you order.
Old Nov 22, 2016 | 06:58 PM
jetsr6's Avatar
jetsr6
I have two videos here. I'll make a adjustment tomorrow and do this again.
trim.8A16DD87-FC84-478F-B238-89088BADDEAE.MOV
trim.AC84E1AD-66B1-406F-8A72-AB65F0DA5622.MOV
Old Nov 24, 2016 | 07:58 AM
jetsr6's Avatar
jetsr6
This will be last video because I need to find a good clutch now. Mine broke in this video
I did make a adjustment to the harder side but not much changed. Doesn't real blow off until 5 psi or more. I hit 15-16psi in this video.
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
Old Nov 28, 2016 | 01:39 PM
Thanks for the video, sorry to hear about the clutch. What have you been looking at, clutch masters, OS Giken?
