Help! This is strange
Old Sep 21, 2016 | 06:50 AM
Givicce's Avatar
Givicce
So I purchased 2005 mcs back in may. It had 111,000 miles on it. Now it has 120,000 it had a sea for a while for a post cat o2 but after fuel filter that was gone. Now this is where it gets weird. I used to get a eml light every morning for a p1498. But it went away after the first drive or second start. Now I get eml sea in the morning then eml goes away and see is on a few more times then its gone too. I never have limp mode. I think I have a vac leak because 12.7 at idle but no loss of power what so ever. I have done a lot to fix things and everything thing helps but I don't understand why the lights go away. Is my car just bipolor or is something serious. The code is always p1498. Unmetered air after compressor. again I have done everything. Nothing changed. No noises no over heating and 23 mpg although after doing a few things last night like fuel purge valve ic boots and fixing my CAI it is increasing. I just dont understand this. Good compression. Not lean or rich. No smells. Just strange. And again never limp mode. Please help! Thank you.
Old Sep 21, 2016 | 09:24 AM
nkfry's Avatar
nkfry
Check the BPV for proper operation, the black plastic intake duct is also prone to cracking at the plastic welds. Also make sure the vacuum sources are all connected under the SC horn, there is a couple from the throttle body that apply vacuum to the reed valve, and one from the intake manifold to the fuel pressure regulator that is common to come off the intake manifold.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 21, 2016 | 10:03 AM
Givicce's Avatar
Givicce
I checked everything I do have the black inlet duct but I didn't do it yet because I wasn't sure if it would work. And I don't want to get a new bpv but again not sure. All vac lines are fine I don't understand why the light go off
Old Sep 21, 2016 | 01:54 PM
nkfry's Avatar
nkfry
The light goes out after 3 successful ignition cycles of not seeing the fault and stores the codes.
Phone:586-792-6464
Old Sep 21, 2016 | 01:59 PM
Givicce's Avatar
Givicce
So why is it coming on in the morning everyday in general?
Old Sep 21, 2016 | 02:17 PM
nkfry's Avatar
nkfry
Because you haven't fixed the problem yet.
The lights do a bulb test every time the car is started, they should all go out after test is complete.
Phone:586-792-6464
Old Sep 21, 2016 | 03:39 PM
Givicce's Avatar
Givicce
Well I realize that. But I have done everything
Old Sep 21, 2016 | 05:13 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Green jam gasket at SC for intake duct horn possibly?....Replace the whole duct and jam gasket. The attaching plastic lobe has a hole for a bolt and it develops into an oblong hole making it somewhat loos and the gasket dries out allowing unmetered air to be sucked in....Mine went south at about 130K....Nothing to lose, sounds like you did everything else.....
Old Sep 22, 2016 | 05:31 AM
Givicce's Avatar
Givicce
I have the gasket and duct sitting on my desk. Just wasn't sure how hard it was too do. When you do service mode do you need to drain the radiator? Or flush it? Because that is not cheap for coolant
Old Sep 22, 2016 | 06:45 AM
nkfry's Avatar
nkfry
You can remove the intake duct without breaking the cooling system open.
Go to service mode, let the core support hang down from the coolant hoses, and you have more than adequate access to the intake duct.
Phone:586-792-6464
Old Sep 22, 2016 | 08:50 AM
ZippyNH's Avatar
ZippyNH
Besides that....the cooling system is often neglected....the fluid should be changed every 36-48 months in a gen1.... remember you have a cast-iron block and coolants are formulated for all aluminum motors in most cases...
If you did have to drain the system with fresh coolant, just catch it with a clean bucket....
Sounds like you're u have done "everything" but what needs to be done to fix the problem... frustrating....it happens.
Old Sep 22, 2016 | 09:32 AM
Givicce's Avatar
Givicce
My fear is that i just did a coolant flush about 2 weeks ago. So I don't wanna waste it and I don't have clean buckets and I can't get them with my car in the air haha. Anyways I'm trying to figure out service mode because the ac condensor
Old Sep 22, 2016 | 09:46 AM
ZippyNH's Avatar
ZippyNH
You just fold/swing it to one side....tie it up rather then let it dangle...no need to disconnect it.
Old Sep 22, 2016 | 09:48 AM
Givicce's Avatar
Givicce
Thank you. That works for the radiator too right?
Old Sep 22, 2016 | 11:32 AM
Filmy's Avatar
Filmy
If you go to a hardware store and purchase a couple of long bolts with washers (I can't remember what size exactly, but they're the same thread/pitch as the core support/bumper bolts) you'll be able to slide the entire core support forward on the long bolts. You may have to disconnect the upper radiator hose, but that won't empty your coolant and you can just top it off again when you're done.
ModMini on YouTube demonstrates this in one of his videos - I think it's his "Service Mode" vid.
Old Sep 23, 2016 | 08:51 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
This tech article here might also help you while you put your MINI into service mode: http://www.pelicanparts.com/techarti...er_Removal.htm.
888.280.7799 | 6am - 5pm PST
Old Sep 23, 2016 | 09:27 AM
doomsdaybob's Avatar
doomsdaybob
I bought my bolts from McMaster-Carr but your local Ace Hardware may have them too.
http://www.mcmaster.com/#91310a566/=14am7t9
High-Strength Uncoated Steel Cap Screw - Class 10.9
M8 Thread, Pitch: 1.25, 100mm Long
Merv
Oct 25, 2016 09:07 PM
BruceJ
Aug 16, 2016 02:48 PM
greatfolder
Aug 10, 2016 07:52 AM
bongi1220
Tires, Wheels, & Brakes
Aug 10, 2016 02:50 AM
OutMotoring
Aug 9, 2016 10:33 AM
