Problem on every first start (idle and clutch) [Video]
Old Sep 16, 2016 | 03:45 PM
haxmed's Avatar
haxmed
Hi people, I've been experiencing this problem for more than a year now. Took the car to two licensed repair shops, they couldn't find the cause of the problem. So this is what happens:
Every day, when I start the car for the first time that day (cold or warm weather, doesn't make a difference), it starts up normally (without a stutter etc.), drives normally until I press the clutch or put it in idle, that's when the rpm just start to go up and down until it hits zero,and the car turns off (not totally but kinda like the start/stop system), then usually (not always) the Start/stop system icon appears on the screen, and i have to press the ignition button to start it (if i keep the clutch pressed, and don't push the gas pedal, sometimes it can't start, like in the video).
The car does show from time to time the yellow engine light, which at the repair shop they told me is because of a problem with the oxygen sensor. But I think it's unrelated?
It's not a big problem, because i realized that the solution is just to stop the car and turn it off completely, and then start again, and everything works fine. But it is pretty annoying. Hope I described it well, ask if it's a little confusing
Here is an example video i recorded for the mechanics that tried repairing it to see (delete the spaces in link to visit it). drive.google .com /file/d/0BxdFHH8DMqC4YllwNVZmRGkzT1U/view?usp=sharing
If anyone knows what is the cause, or has a some advice, please help
Relsoc
R55 :: Clubman Talk (2008+)
Sep 7, 2016 09:00 PM
thebombardier
Sep 2, 2016 08:31 AM
Jckol
Aug 24, 2016 09:30 PM
E-dot
Aug 23, 2016 07:31 PM
tretowrules
Aug 23, 2016 07:45 AM
