R50/53 2003 Mini P0300 - Random Misfire
Old Sep 12, 2016 | 09:28 PM
cpitrone's Avatar
cpitrone
Hello all,
I need advice from someone out there. In the last year my check engine light has gone on and off. It has always been P0300 - Random Engine Misfire and no other codes show up. I have replaced the Fuel Pump, Belt Tensioner, Spark Plugs, Plug Wires, and the Coil Pack. The idle is rough and the light usually goes on when I'm on the highway and sometimes when I start him it usually is not quick to turn over. Im running out of ideas and patience, does anyone else know what it might be??
Old Sep 13, 2016 | 07:28 AM
nkfry's Avatar
nkfry
What is your fuel pressure at idle?
Compression numbers?
Is the timing cassette in time?
Check for vacuum leaks?
MAP sensor operation?
Crank/cam signals?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 13, 2016 | 08:32 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Some other areas to check: https://www.obd-codes.com/p0300
888.280.7799 | 6am - 5pm PST
Old Oct 9, 2016 | 09:23 PM
05justacooper's Avatar
05justacooper
P0300 code
Originally Posted by cpitrone
Hello all,
Hey,
I just dealt with this on my '05 R50. That code is a little vague.
Here's what I did-
1. Replaced my spark plugs, wires, & wiring harness (inexpensive).
Light came back on.
2. Checked my compression, cleaned intake (inexpensive).
Light came back on.
3. Replaced Serpentine belt and Harmonic balancer (not cheap).
Light has not comeback on.
Tuns smoother, quieter, and I'm at 100k miles, so I chalk it up to my 100k tune-up. Hope that helps.
Jordan94
R60/R61 Stock Problems/Issues
Oct 23, 2016 04:10 PM
TheBingoBalls
Sep 7, 2016 04:37 PM
Jetmoe
R55 :: Clubman Talk (2008+)
Aug 30, 2016 05:44 PM
LittleWingR53
Aug 30, 2016 12:04 PM
cop1406
Aug 16, 2016 09:33 PM
