Idle Woes
Old Aug 30, 2016 | 07:11 AM
LittleWingR53's Avatar
LittleWingR53
Idle Woes
Hi,
I have an 02 r53 and I've been having the intermittent issue of all the gauges dying at idle. This usually only happens when the AC is on, but I've also seen it happen when the steering wheel is turned when the car isn't moving. This on occasion resets the ECU which really baffles me.
Old Aug 30, 2016 | 07:37 AM
MiniToBe's Avatar
MiniToBe
Hello, I am not an R53 person but in some other threads i read that it could be your charging system which includes the battery, alternator, and WIRINGs. when did you start having the issue, how old is the battery, if you start the car and remove the battery while running, would the car shut off or get weaker?
Old Aug 30, 2016 | 07:48 AM
LittleWingR53
Thanks for the quick reply.
I started having the issue about a month ago, The battery is an Optima Red Top with a build date of 06/14. I'll have to get back to you about disconnecting the battery. I'm at work at the moment.
Old Aug 30, 2016 | 08:06 AM
MiniToBe's Avatar
MiniToBe
ok, keep us posted. finally, when you turn the steering, does the car feel like it wants to shut off?
Old Aug 30, 2016 | 08:10 AM
LittleWingR53
No, the engine continues to run strong.
Old Aug 30, 2016 | 08:16 AM
MiniToBe's Avatar
MiniToBe
when you get a chance, rev the engine a little higher (let's say 2k rpm or something like that [me just throwing numbers just to test the system]) so the alternator can put out some more juice and turn the AC and see what happens, do the same and turn the steering wheel, then do the same with AC and steering are working and see what happens.
Old Aug 30, 2016 | 09:14 AM
LittleWingR53
The car ran fine and the gauges stayed functioning.
Old Aug 30, 2016 | 09:28 AM
MiniToBe's Avatar
MiniToBe
humm...interesting. check the voltage on the battery before and after starting the engine and see if it is with in range.
Old Aug 30, 2016 | 10:22 AM
LittleWingR53
The voltage is 12.38v with the car off and 14.2v with the car on
Old Aug 30, 2016 | 10:29 AM
MiniToBe's Avatar
MiniToBe
how about the voltage from the positive terminal to the chassis before and after the start?
Old Aug 30, 2016 | 11:19 AM
LittleWingR53
12.35 off and 14.23 on
Old Aug 30, 2016 | 11:33 AM
MiniToBe's Avatar
MiniToBe
The voltages seem consistent. But you notice that only when you rev up the engine everything seems to work fine. Also the voltage readings indicate good terminal connections assuming they are tight. I dont want to say it is a weak alternator yet, but I hope other members chip in!
Old Aug 30, 2016 | 12:04 PM
LittleWingR53
That was also my thought. I hope it isn't given the price of a new alternator.
InnocentiMini
Oct 12, 2018 06:10 AM
MothAudio
Apr 3, 2016 06:34 PM
pugmin
Apr 3, 2016 06:26 PM
GBMINI
May 30, 2002 11:41 AM
