Suspension R53 GP rear suspension clanking
Old Aug 25, 2016 | 03:27 PM
rob76turbo's Avatar
rob76turbo
I have a very loud metal on metal clanking sound coming from the rear suspension. I do have the madness sway bar installed. The sound seems omni-directional and comes from the center rear of the car. The clanking is constant over anything but a billiard smooth road.
I have had the car up on jack stands twice and looked at all the components and cannot find anything amiss. Took it to my shop, they got it up on a lift and hammered (with a rubber mallet). They could find nothing wrong either.
I am at a loss....
Any ideas?
Old Aug 25, 2016 | 05:47 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Do you have adjustable droplinks installed? If so, have you checked them for condition and possible pre-load. There should be none. To check, you'll need a drive-on rack or jack the rear up and then lower the rear wheels onto ramps or similar equal height supports.
Old Aug 25, 2016 | 08:12 PM
ZippyNH's Avatar
ZippyNH
Might be a swaybar clearance issue as suggested, but also check the exaust....
The mounts tend to rust...even come unwelded from the unibody...or the rubber connectors can fail....either way the exaust can bump a bit at times...
Old Sep 1, 2016 | 08:24 PM
rob76turbo's Avatar
rob76turbo
The clanking got worse and worse. So I put the car up on stands, fully charged my cordless impact wrench and hit every bolt that I could reach. Noticed that several of them turned a bit as I put the impact wrench to them. Hmmmm, maybe when I installed the Madness Rear Sway bar, I did not torque them to spec. But whatever it was, by hitting all the bolts again with my impact wrench, it cured the clank. Woo Hoo! My Mini is back!
jetmechinnc
Jul 29, 2024 08:53 AM
Mini_Vinnie
Suspension
19
Aug 24, 2016 11:19 AM
Rchitct
Factory JCW Talk (2009+)
Apr 12, 2016 12:03 PM
Nick89
Apr 5, 2016 05:47 AM
wzabrouski
R60/R61 Stock Problems/Issues
Mar 23, 2016 04:53 PM
