R50/53 Xenon Retrofit?
Old Aug 25, 2016 | 12:37 PM
illzoni's Avatar
illzoni
Xenon Retrofit?
I'm still shopping for a Cooper and looking at a few S models. One has Xenons and the others don't.
Were the Xenons an OEM option?
Can Xenons be retrofit into one without?
Difficult? Costly?
Of course, I'm not fully aware of the pros/cons of the Xenons, either.
Thx,
Jon
PS - I could swear I already posted a similar query, but can't find it.
Old Aug 25, 2016 | 03:52 PM
BlwnAway's Avatar
BlwnAway
Yes, xenon/hid lights were a factory option, personally I love them and will never have another car without them, better visibility, better reflectivity off road signs, striping and markers.
A full factory retrofit is expensive and there may even be some wiring issues, but there are decent aftermarket options available from full kits that include housings to basic bulb kits that can be used in factory projector housings (if you find a used set of those)
Just be certain that you use a projector style housing, xenon/hid bulbs should not be installed I'm standard headlight housings, they create glare for the other traffic and in some states are actually illegal. The projector lenses are needed to focus the brighter beam.
Old Aug 25, 2016 | 07:29 PM
illzoni's Avatar
illzoni
Thanks for your reply. Helped clarify a decision for me.
Thx,
Jon
Old Aug 25, 2016 | 07:55 PM
ZippyNH's Avatar
ZippyNH
Of note....
There were TWO different style xenon headlights on gen1 cars....both used halogens for high beams...
The difference is the 2005+ "refresh" headlights are projector beams....superior units....
The 2002-2004 units are actually reflector units....both units had washer jets active when sold from the factory with xenon's....usually not active on retrofit units...
The newer ones had replaceable ignitors....the older ones, not so much....could be done...but not officially. They use slightly different bulbs.
Yes, once you have xenons you are spoiled.
srinimini
May 10, 2021 11:18 AM
kfinkl
Sep 10, 2017 08:03 AM
8eMINI
Apr 8, 2016 07:44 PM
R53Warrior
Apr 3, 2016 08:35 AM
PinkMiso
Mar 11, 2016 10:32 AM
