R50/53 Recommended water pump?
Old Aug 19, 2016 | 11:41 AM
KnighTT's Avatar
KnighTT
So, there are a lot of water pump options for the R53. From Cheap, to OEM.
What do you guys have experience with? While avoiding a $100+ WP.
URO Parts, Gates, OEM, KoolMan, AC Delco, Beck Arnley, GMB...
I will be running a 2% CS crank pulley, and a 15% Alta SC. So, keep it in mind it won't just just a daily driver.
Thanks.
Old Aug 19, 2016 | 12:52 PM
Mini Mania's Avatar
Hi KnighTT!
Here is an application guide that shows recommendations for both OEM and Aftermarket. Don't forget your August discount. Please let us know if we can help!
http://new.minimania.com/Mini_Cooper...lication_Guide
Old Aug 19, 2016 | 04:55 PM
Shawnnn's Avatar
Shawnnn
And I thought I was cheap.
$99 from wmw for oem and maybe never need another water pump for the car.
Old Aug 19, 2016 | 07:01 PM
fancy sauce's Avatar
fancy sauce
I imagine an aftermarket with metal instead of plastic impeller could be better than oem. OEM isn't ALWAYS the best option for replacement parts
Old Aug 19, 2016 | 07:29 PM
Shawnnn's Avatar
Shawnnn
https://www.waymotorworks.com/r53-water-pump.html
When I changed mine at 100k it looked perfectly fine. Im apt to trust wmw, they work on a ton of Minis and recommend oem for the water pump.
I'm no oem snob, our Mini's have plenty of crap parts from the factory, I don't think the water pump is one of them though.
Old Aug 22, 2016 | 03:49 PM
Mini Mania's Avatar
Water pump
We've realized after 40 years with the brand on the street and track, and having the first BMW MINI in the USA, that OEM can be best for certain applications. In this case, OEM or quality aftermarket like Value Line, or factory remanufactured like the dealers use, will fit the bill.
Old Aug 23, 2016 | 01:08 PM
nkfry's Avatar
nkfry
Thanks.
URO Parts, Gates, OE, Beck & Arnley, GMB, Saleri are all reputable brands I wouldn't hesitate to install any of them on my car or a customers.
The time it takes to get to the water pump and labor to install it should also be taken into consideration when wanting a "cheap option", while you save a few bucks up front you could be spending the same money in a few months to a few years time.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Aug 23, 2016 | 01:51 PM
KnighTT's Avatar
KnighTT
Going with OEM Mini.
$108 looks like the best price I have found so far.
Old Aug 23, 2016 | 03:35 PM
Mini Mania's Avatar
Water Pump
$101.20 with August 12% discount:
http://new.minimania.com/part/NME768...r-Pump-R52-R53
This is the same replacement unit used by the MINI dealers.
DRoc7822
Feb 11, 2017 08:39 AM
Curt16
Apr 11, 2016 01:40 PM
CLTMinifan
Apr 6, 2016 12:01 PM
davidg5700
Mar 23, 2016 07:44 AM
Doc Pain
Mar 14, 2016 09:01 AM
