Malfunction light - Help
Old Aug 14, 2016 | 02:59 PM
Rastoff's Avatar
Rastoff
Today while driving down the freeway I went to accelerate past a semi-truck. I didn't down shift, I just pressed the accelerator. As I did this, this light came on:
I stopped immediately and looked in the manual. On page 133 it said, "Lights up in yellow:
Full engine power no longer available
You can continue on your journey, but moderate your speed and exercise due caution. Have the engine checked as soon as possible."
I then continued home which was only about 4 miles. Once home, I used my OBDII reader to check for codes; it didn't have any. There was a note about a misfire.
Anyone know any possibilities about what might be wrong?
The car runs fine and I've noticed no loss in power. It didn't make any funny sounds when the light came on and isn't making any now. The only indication that anything might be wrong is this annoying light.
I will call the mechanic tomorrow. In the mean time, is there a way for me to clear this fault?
Just for the record:
2008 Mini Cooper S
Manual Transmission
Old Aug 14, 2016 | 06:42 PM
Rastoff's Avatar
Rastoff
No one? Not even to tell me to stop posting things you've already hashed out?
Old Aug 14, 2016 | 07:11 PM
oldbrokenwind's Avatar
oldbrokenwind
One way to clear the ECU is to disconnect the battery for a couple minutes, usually just the ground side. There might also be code scanners with a cel clearing function --- try your local auto parts store.
Best way to prevent this particular cel, when punching it, is to ensure there's minimal load on the engine --- RPM's are high, like 3 - 4K. This assumes your engine is in good condition.
Old Aug 14, 2016 | 07:54 PM
Rastoff's Avatar
Rastoff
Thank you oldbrokenwind.
Old Aug 15, 2016 | 08:24 PM
Rastoff's Avatar
Rastoff
OK, it's at the mechanic. I have to wait a day or two because they're booked.
They gave me a Hyundai Elantra as a loaner. Life sucks at the moment.
agordon1337
Sep 25, 2020 04:24 PM
angeltrain31
Jun 12, 2016 05:58 AM
Cmv138
Apr 11, 2016 06:18 AM
sirron
Site Feedback
Jul 26, 2002 08:51 AM
