R50/53 Coolant temp range?
Old Aug 10, 2016 | 02:24 PM
Photodesign's Avatar
Photodesign
Coolant temp range?
I've searched the forums but can't find a consensus. What is the normal coolant temperature range in the summer?
Mine is currently 205-210 Fahrenheit. It seems like that might be a little warm.
Thanks!
Old Aug 10, 2016 | 05:26 PM
Mini Mania's Avatar
That sounds like the normal range. The warning light will go off at 240 degrees, so probably not critical. How many miles on the car, and do you know if the radiator has ever been flushed? What year?
If you do need some parts you can check out this guide:
http://new.minimania.com/Search_Results/radiator/All
Old Aug 10, 2016 | 06:09 PM
Photodesign
It's a 2004 with 72K.miles. I started anther thread earlier asking about my cooling fan behavior, but some suggested it might be normal behavior. So I just wanted to see what other drivers with OBI gauges are seeing if they monitor their temps.
Old Aug 10, 2016 | 06:40 PM
elvis cole's Avatar
elvis cole
For what it's worth, my 06 JCW with 76K runs between 188 and 194, winter and summer here in the Central Valley.
Old Aug 10, 2016 | 09:51 PM
Andrew Riley's Avatar
Andrew Riley
Mine runs around 210 lately... Then again in SC humidity is stupid crazy, feels about 110 everyday this past month.
Old Aug 11, 2016 | 04:54 AM
Saltysalt's Avatar
Saltysalt
typically I run between 195 and 205 depending on the style of driving
Old Aug 11, 2016 | 12:15 PM
Photodesign
Thanks for the responses! I'm going to look into my high speed fan to see if that's what is causing me to run a little warm.
Old Aug 12, 2016 | 10:24 AM
ryanleeis's Avatar
ryanleeis
usually it should run around 198 if everything is normal .. if your getting to the 210 range and it's not cooling down your stage one fan resistor is blown . just turn on your ac so your second stage works all the time until you can change the resistor
Jckol
Jan 28, 2022 11:22 AM
runswithsizzers
Aug 15, 2016 07:24 AM
GimmeBoost
Jul 21, 2016 06:10 PM
joel.nudi@gmail.com
Jul 19, 2016 10:47 PM
MMM
Jul 13, 2016 06:24 PM
