has anyone got please?
Old Aug 5, 2016 | 03:53 PM
Jcw_steve's Avatar
Jcw_steve
a wiring diagram for the dual gauges on an r53 the ones behind the steering wheel ? I need to know what wire does what as per my other thread with the problem I am having
much appreciated!!
Old Aug 5, 2016 | 04:06 PM
Jcw_steve's Avatar
Jcw_steve
Old Aug 6, 2016 | 04:28 PM
Jcw_steve's Avatar
Jcw_steve
Anyone?
Old Aug 7, 2016 | 12:36 AM
rkw's Avatar
rkw
See the diagram attached to this post: https://www.northamericanmotoring.co...ml#post4232081
The wiring is the same whether single tach or dual gauge. "Auxiliary instrument cluster" in the diagram is the steering column gauge (single or dual). "Instrument cluster control module" is not physically a separate module, but electronics located on the circuit board of the center dash unit (speedometer, chrono pack, or nav). Everything is digital electronics. The only wires that actively do something are the CAN bus. 58G is night illumination. Everything that happens on the gauges comes from commands/messages sent to it on the CAN bus.
Old Aug 7, 2016 | 12:54 AM
Jcw_steve's Avatar
Jcw_steve
Thanks so much mate that's exactly what I was after ����
Old Aug 9, 2016 | 08:06 PM
greatfolder's Avatar
greatfolder
Does that mean the Chrono pack and Nav are interchangeable? I really would prefer to see coolant temp and oil pressure over a crappy nav and fuel consumption.
Old Aug 10, 2016 | 08:29 AM
rkw's Avatar
rkw
They are sorta kinda interchangeable. Programming is required. It should work if you use a new Chrono unit. There could be issues with a used unit. I haven't heard of anyone actually trying it.
InnocentiMini
Oct 12, 2018 06:10 AM
2001f4s
Apr 29, 2016 05:42 AM
MothAudio
Apr 3, 2016 06:34 PM
GBMINI
May 30, 2002 11:41 AM
