R50/53 Removing Driving Lights
Old Aug 5, 2016 | 07:43 AM
djp2313's Avatar
djp2313
I've taken off the brackets and snipped the wires on my driving lights. Now I am left with two exposed wires in the hood.
What's the best way to cover the wires knowing that however it's done they will be exposed to the engine heat and vibrations. Crimping them and putting on a connector is all I'm coming up with.
Taking the wires out completely would of course be ideal but I'm not positive I want to leave them off so leaving the wires in would make things a lot easier now and possibly in the future as well.
Old Aug 5, 2016 | 09:10 AM
gpwpat's Avatar
gpwpat
put wire nuts on the end. and tape them up, stuff under the hood liner.
Old Aug 8, 2016 | 07:37 AM
Eric_Rowland's Avatar
Eric_Rowland
If you're concerned about power accidentally going to the wires, just pull the auxiliary fuse for the driving lights. As gpwpat said, wire nuts and a little tape and you should be good. Zip tie will hold them wherever you desire.
Old Aug 14, 2016 | 10:38 AM
Islandpotter's Avatar
Islandpotter
What year is your Mini.... I would be interested in buying your brackets if they will fit a 2011 Mini S convertible. Thanks
Old Aug 15, 2016 | 12:54 PM
They will not fit the 2011 MINIs , the ones above I believe are factory for the gen 1 MINI 2002-2008.
mikeyr
Classic Mini Talk
Apr 26, 2016 02:12 PM
Minilov
Apr 18, 2016 09:47 AM
Minilov
Apr 15, 2016 12:21 PM
Verruckt
Jul 23, 2002 07:58 AM
LuC727
Jul 19, 2002 05:32 AM
