R60 Borla S-type vs Megan Racing cat back
Old Aug 1, 2016 | 07:41 PM
felix_434's Avatar
felix_434
Talking Borla S-type vs Megan Racing cat back
Looking at both cat back exhausts. The Borla S-type (more aggressive) exhaust sounds pretty loud, and the Megan is a tick louder than stock. However I'm planning on a cat less downpipe, 2nd cat, & res delete. Would the less expensive Megan racing exhaust sound about right with the listed above? Does anyone know hp gains with either?
Old Aug 2, 2016 | 06:15 AM
JuanTheHuman's Avatar
JuanTheHuman
Hi FELIX,
Please be advised that these 2 systems are non "Cat-back", but rather, "Axle-back" systems.
The good news is that both systems are made out of T304, rather than T409, which is key.
In terms of HP gains, I would not expect anything more than 5-8 HP. I'm just ballparking, but axle-back systems are 90% for sound and 10% for flow. However, you will definitely start freeing up some flow when you begin with the aforementioned additions.
Please also note that the diameter goes down to 2.25", which is pretty nominal over OEM.
I would take a look at the VIP Custom Parts full-exhaust system. The system is madrel-bent, tig-welded T304 2.5" along its entirety. Since you plan on doing 2nd Cat & Rez, you could avoid having to create some sort of custom setup between the 2nd Cat & Rez delete, midpipe, and axleback. The awesome thing about this kit is that it comes all together, from the DP to the tip, all PNP. Additionally, for the amount you would be spending between the axle-back, a custom midpipe, custom 2nd cat & rez section, etc.... you would probably be breaking even and be able to avoid all the trouble.
The reason I am recommending all of this, is because I wet through that very situation. I started out with the NM Engineering Cat-back. Then I decided I wanted to go with an Akro DP and a 2nd cat & rez delete. I actually had to call VIP and have them custom cut only the front section of their full-exhaust system for me, which I then had to custom mate up to my NM.
It all came out great, and I absolutely love the sound between all three: Akro DP, VIP Front Section, NM Catback.....but if I could do it all over again, I would just buy the VIP Full exhaust from scratch. Please note that there are plenty of other manufacturers and forum-wide sponsors that offer their own full-exhaust systems, which are awesome as well. I am just noting from my own experience.
In the below link is my Page 3 of my build thread, where you can see some pic of the VIP front section and the NM catback. You can see where I mated them, that I actually had to reduce the 2.5" VIP to 2.25" NM.
https://www.northamericanmotoring.co...-begins-3.html
Here is a link to VIP's countryman page:
http://www.vipcustomparts.com/R60%20parts%20page.htm
Good Luck! Drive Safe & Drive Often. Rubber Side Down. Over & Out.
Old Aug 2, 2016 | 02:21 PM
Mini Mania's Avatar
Cat Back Exhaust
If you are looking for a true Cat Back system, here is a useful application guide to help you:
http://new.minimania.com/MINI_Cooper...lication_Guide
Here also are several suggestions!
http://new.minimania.com/Search_Resu...20back/default
Old Aug 3, 2016 | 09:42 PM
felix_434's Avatar
felix_434
Thanks guys for the great info! I hooked up with VIP and will go with a full system! Pics to come!
Old Aug 22, 2016 | 04:50 AM
felix_434's Avatar
felix_434
Got my CNT cat-less downpipe on as well as my full VIP exhaust. It sounds good, and is a bit loud at times but I like it. lol The mechanic who installed it said there was a small leak where the downpipe and exhaust meet. Still need to add some high temp silicone to it.
speedyg56
Jun 8, 2016 07:07 AM
peter314
Jun 5, 2016 10:15 AM
AFN704
May 20, 2016 03:55 PM
bintliff25
May 15, 2016 05:36 PM
Esoterik
May 5, 2016 03:58 PM
