R50/53 Changing to duel gage pod 2004 r53
Old Jul 30, 2016 | 10:56 AM
SethC's Avatar
SethC
Hey everyone I'm trying to figure out if it's possible to change from my single steering wheel gage of my r53 to a duel gage cabrio of the same year. Thanks!
Old Jul 30, 2016 | 12:54 PM
rkw's Avatar
rkw
The cabrio began with 2005 model year, so there are none with the same year as yours.
If you want to swap only the tach to a dual gauge, it has been attempted before but never successfully. It is possible (has been done before) to swap in the entire Nav system along with dual gauge and harnesses from a donor car.
Old Jul 30, 2016 | 01:05 PM
SethC's Avatar
SethC
Bump
Old Jul 30, 2016 | 01:11 PM
RB-MINI's Avatar
RB-MINI
Yep, things don't seem to work 100% if not done with a new NAV or Chronopack center cluster. The center cluster controls the gauges on top of the steering column. At the minimum, the dummy lights and warnings are incorrect because they are in a different position on the steering column gauge. You might be able to correct this with custom gauge faces, but the 2 gauge retrofit isn't as easy as it seems.
Old Jul 30, 2016 | 02:13 PM
rkw's Avatar
rkw
Bump
Seriously? Two hours after you posted the question?
InnocentiMini
Oct 12, 2018 06:10 AM
2001f4s
Apr 29, 2016 05:42 AM
MothAudio
Apr 3, 2016 06:34 PM
GBMINI
May 30, 2002 11:41 AM
