R50/53 Tachometer signal tap.
Old Jul 8, 2016 | 01:31 PM
GreekDrifter91's Avatar
GreekDrifter91
anyone know a good place where i can tap into and pick up a tachometer signal? i have a boost gauge that will pick up engine speed as well. and want it so i can log rpm, boost, and afr.
can i use the wire going to the factory tachometer and splice into that?
Old Jul 19, 2016 | 03:11 AM
chris.j.lamb's Avatar
chris.j.lamb
OBD port
http://wtxmc.org/MiniCooperDocs/WIRING.pdf
pin 9?
yes pin 9 white/red
http://www.minimania.com/pdfile/NMI7645_INSTR.pdf
Old Jul 19, 2016 | 05:03 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
uhh that's not for regular rpm monitoring pretty sure pin 9 is a canbus pin
Old Jul 20, 2016 | 04:28 AM
chris.j.lamb
No CAN is 6 & 14.
Pretty sure that pin 9 is engine rpm.
Old Jul 20, 2016 | 09:04 AM
GreekDrifter91
Thankyou ill try pin 9 when im done with the rest of car. I thought i would have to splice into wiring if the main tachometer gauge
Old Jul 20, 2016 | 03:28 PM
sevin's Avatar
sevin
OBD2 has some standards for pin locations. 6 and 14 go to CAN BUS high and low.
Old Jul 20, 2016 | 04:03 PM
MrBlah's Avatar
MrBlah
ahh On our cars it's not can it's k-line isnt it? It's horribly slow 3rd party data loggers connect to the real canbus line instead
macspeed704
Nov 16, 2016 08:22 AM
SpiceOrangeR56
Sep 6, 2016 07:19 AM
Flyinace2000
May 10, 2016 09:42 AM
Val P
Apr 27, 2016 06:37 PM
newjcwdriver
Apr 21, 2016 06:48 AM
