Will be needing to replace clutch...
Old Jul 4, 2016 | 08:43 AM
53ryder's Avatar
53ryder
I think my 2005 base model Mini-Cooper(R52) , with 5 speed manual tranny, is going to need a clutch replaced soon. Pedal is almost all the way out before any grip/movement is felt. It has 74000 miles on it. Am guessing the clutch is original.
Looking for a shop in Seattle and places north up to Everett that can do a clutch replacement. Oem clutch, don't need something fancy or for racing.
Any ideas? TIA!
Glenn
Old Jul 7, 2016 | 08:56 AM
Check the local google search for shops, or if you can find a BMW / MINI shop up there. Reach out to Alta performance out in Hillsboro, OR ( we carry there product ) and they might be help you with a shop.
And for the parts
For an R50 R52 MINI Cooper ( Non S ) which is what you said you have, it has a Getrag 5 speed transmission: 7/2004+ production.
Here is the clutch kits: 21207561754
http://www.ecstuning.com/Search/SiteSearch/ 21207561754/
Centering tool: 83300495051
https://www.ecstuning.com/Search/SiteSearch/83300495051/
For the flywheel , you can resurfaces them once, but I would not resurfaces them multiple times. If you do get it resurfaced go to a place who knows how to do them, and has a huge background with flywheels. 11227535599
http://www.ecstuning.com/Search/SiteSearch/ 11227535599/
8 collar screws for the center
11227560578
http://www.ecstuning.com/Search/SiteSearch/11227560578/
6 Presssure plate bolts Part # 21211043920
http://www.ecstuning.com/Search/SiteSearch/21211043920/
Check the guide tube , they can shows wear and shows some ring wear from the clutch release bearing. It also contain the seal ( separate part) on the back which can seep fluid and into the bell housing.
Guide Sleeve 23117545085
http://www.ecstuning.com/Search/SiteSearch/ 23117545085/
Guide Sleeve Seal
http://www.ecstuning.com/Search/SiteSearch/ 23117549008/
Thanks and hope that helps.
Old Jul 8, 2016 | 03:57 AM
53ryder's Avatar
53ryder
Since we're on the topic, just what does a lighter weight flywheel do for a car's performance? Less weight mean better mileage since the engine and tranny is spinning less weight? Does the clutch 'feel' different? Can anyone explain flywheels for dummies?
Glenn
Old Jul 16, 2016 | 05:09 PM
Shawnnn's Avatar
Shawnnn
http://www.psmini.org/
If you haven't done your clutch yet, check out this website and have corners do it.
Old Jul 16, 2016 | 05:28 PM
53ryder's Avatar
53ryder
Who is "corners"? And no, haven't done the clutch yet.
Glenn
Old Jul 16, 2016 | 05:42 PM
Shawnnn's Avatar
Shawnnn
Did you click on the link ?
Seattle area Mini website.
If I lived anywhere near Seattle and needed someone to work on my car, the first person I would contact is the person on that website with the forum name corners. Think his real name is Kurt.
Another link :
http://www.psmini.org/forum/r53-clut...opic10431.html
Old Jul 16, 2016 | 05:50 PM
53ryder's Avatar
53ryder
I did click on the link that sent me to the homepage of Puget Sound Mini. Didn't see any reference to a 'corners'. This latest link does show what you were orginally trying to tell me thanks.
Glenn
Old Jul 16, 2016 | 05:53 PM
Shawnnn's Avatar
Shawnnn
He also goes by the name of mod mini. The single best dyi resource we have to fix our cars.
53ryder's Avatar
53ryder
nevermind boo boo on my part!
Old Jul 16, 2016 | 05:55 PM
53ryder's Avatar
53ryder
Thanks for the resource!
Glenn
2nd Childhood
Jul 27, 2019 05:45 AM
minihooligan773
Dec 11, 2018 11:32 PM
jpwins
Apr 18, 2017 04:44 PM
sam.k
Jul 15, 2016 06:11 AM
saturn5rocket
Apr 7, 2016 02:09 AM
