FS:: Slightly mod 03 mini Cooper s r53
Old Jun 30, 2016 | 10:22 AM
minisenpai's Avatar
minisenpai
Post Slightly mod 03 mini Cooper s r53
Year: 2003
Model: Hardtop
Price: $2500
Mileage: 171500
Color: Electric blue
Location (Region): SoCAl
http://losangeles.craigslist.org/lgb...660509727.html
Lovation:Bellflower, CA area. Can meet 50 mile radius.
03 r53 mini cooper s (supercharged) project car.
It runs, I drive it everyday, anywhere.
The plan was to built a daily with the upcoming RMW TVS-900 w/ occasional? autocrossing then focus on aero and bodykit.
Buyer assumes everything.
562-213-5640 text for fastest response.
$2500 FIRM.
If you don't like the price look elsewhere. Repairs were done at CMW and are warrantied for 36 months or 36000 miles. Tags are up to date. No back fees. Will not pay DMV fees and taxes.
I did a recent autocheck on it and it's good. There was an accident back in 2004 by the previous owner, but it seems minor and still has a CLEAN TITLE. Trunk is slightly off mark and you can only tell if you're up close. I am the 4th owner and have pink slip.
Has a few mods:
M7 16% pulley
M7 STP
WMW tensioner stop
WMW stubby antenna
Replaced tensioner 10/2015
Replaced Left outer CV boot 3/2016 at CMW
Replaced radiator resistor fan 3/2016 at CMW
Replaced oil pan gasket 3/2016 at CMW
Replaced o-ring and oil filter housing 3/2016 at CMW
Replaced oil cooler hose 3/2016 at CMW
TSW upper motor mount (stiff, some vibration are felt)
BSH lower motor mount (stiff)
AFE stage 2 CAI
lowering springs (idk brand)
Screamin demon coil pack
WMW red spark plug wires
PRW SFI-rated Fluid gel crank pulley
NGK laser iridium spark plugs
Detroit tuned bypass valve
Canton aluminum coolant tank
Oneball mod w/MagnaFlow 11365 muffler w/oval exhaust (lots of burble and pop, which I like)
Includes a rebuildable ATI crank pulley, timing chain tensioner, alta adjustable tensioner and 1 rear fender marker side light.
Cons:
-needs alignment.
-boost gauge is not connected.
-old car
-paint peals and dings
-car makes a noise here and there because of the tube from the coolant tank.
-abs sensor not connected
-brake sensor went out and needs to be replace (brake pads are fine though).
-recommend front axle to be changed since it's about that time to change
-cracked windshield
-took out the plastic skid plate
-needs to replace windshield wipers
Attached Thumbnails Slightly mod 03 mini Cooper s r53-1.jpg   Slightly mod 03 mini Cooper s r53-2.jpg   Slightly mod 03 mini Cooper s r53-3.jpg   Slightly mod 03 mini Cooper s r53-4.jpg   Slightly mod 03 mini Cooper s r53-5.jpg
Slightly mod 03 mini Cooper s r53-6.jpg   Slightly mod 03 mini Cooper s r53-7.jpg   Slightly mod 03 mini Cooper s r53-8.jpg   Slightly mod 03 mini Cooper s r53-9.jpg   Slightly mod 03 mini Cooper s r53-10.jpg
Old Jul 15, 2016 | 12:42 AM
minisenpai's Avatar
minisenpai
Bump
padman12
Apr 28, 2016 09:15 AM
moremini
Apr 20, 2016 07:08 AM
dn09MCS
Mar 14, 2016 08:50 AM
Khai
Mar 14, 2016 08:27 AM
normstangl
Aug 23, 2007 02:24 PM
