Giving away lifted R60 Countryman Wheels/Tires
Old Jun 12, 2016 | 06:16 PM
Phillip Dobbs's Avatar
Phillip Dobbs
Hello North American Motoring,
I just recently upgraded my wheel & tire setup on my lifted R60 and I am looking to give away my old wheels. The old set are Steel Rims (ProComp 5x120mm 16x8's) and 225/70r16 tires (29" Treadwright Puma Retread's) and I have a total of 5. These will only work with the 2" lift kit and a little modification.
The old wheels are in good shape, balanced and running straight. There are only small scratches to the wheels, and the tires are at about 20% or less. 1 tire is at 100% and the wheel is perfect, it was my spare and was never taken on the road, only left in the trunk in case of a flat.
I live near Richmond, VA and these are currently in storage. If you are interested, I can meet you nearby and we can work out arrangements so you can have the set.
I have loved these tires for the last year, but I really wanted to upgrade to an aluminum setup for the lighter weight and the better visuals.
Let me know if you're interested, here is a pic of the tires from when I went offroading in the snow last winter.
Thanks,
Old Jun 13, 2016 | 11:19 AM
y8s's Avatar
y8s
Will the wheels fit with less sidewall or is the width and offset going to cause problems with even a stock diameter tire?
Old Jun 15, 2016 | 02:27 AM
Phillip Dobbs
Honestly, i use a 1" spacer on the wheels with longer lug nuts to fit. I have pulled out the wheel well shroud, and I had to do some modifications to the inner wheel well metal to flatten it out as the tires were rubbing prior.
If you're just looking to keep a 26" tire and have the rims, I can't verify if this is possible, but it's a maybe. I would say you will still have to do some kind of modification necessary to fit this.
Old Jun 16, 2016 | 07:54 AM
y8s's Avatar
y8s
I just ran the numbers, assuming your ProComps are 4.75 inch backspacing... the offset would be 6 mm.
Stock backspacing with the 17x7's is 6 inches.
That means 2.75 inches more wheel hanging out of the fender. Not sure that would quite make it!
Old Jun 16, 2016 | 10:19 PM
bmwr606's Avatar
bmwr606
i am running 205/70R16 winter tires (27.3 inch OD) on mini oem 16 x 6.5 et 46 wheels with sport suspension (10 mm lower than standard suspension) with no rubbing
Attached Thumbnails Giving away lifted R60 Countryman Wheels/Tires-100_1912.jpg   Giving away lifted R60 Countryman Wheels/Tires-100_1922.jpg   Giving away lifted R60 Countryman Wheels/Tires-100_1910-001.jpg   Giving away lifted R60 Countryman Wheels/Tires-100_1918.jpg   Giving away lifted R60 Countryman Wheels/Tires-100_1920.jpg
Giving away lifted R60 Countryman Wheels/Tires-fb_img_13911083175483506-2.jpg
Old Sep 3, 2016 | 08:48 PM
state0222's Avatar
state0222
are these still available?
quickcoop
Sep 21, 2018 03:40 PM
Tylerlanger1
May 25, 2016 08:13 AM
Sooper NC
Electrical
Mar 29, 2016 02:55 PM
ultrahuck
Mar 25, 2016 11:16 AM
