R60 Switch needed for driving lights
Old May 19, 2016 | 11:19 AM
Vader-S-All4's Avatar
Vader-S-All4
Question Switch needed for driving lights
HELP! I am almost ready to install the driving lights on my R60. I have all the parts except 1... the switch...
However, I do not want to use the standard switch which mounts in the knee bolster under the steering wheel. My thought is to replace the switch pack under the toggle switches with the pack that BMW makes with a rear fog button in it. The part number for this pack is: 61319804922.
My thought is that I could use the rear fog button for my driving lights. What I need to know before I drop the $200+ on this pack is if that will actually work? Has anyone tried this? Please do not respond to this thread with the note of: "scan through the other threads..." I've already done that, and unless I have completely missed something, that comment will not help me.
PLEASE help!!! Useful information will be greatly appreciated!!!
Old May 19, 2016 | 12:23 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I'm thinking that it requires coding. Don't think that those are regular contact terminal switches.
Old May 19, 2016 | 06:38 PM
devilmotorsports's Avatar
devilmotorsports
The switch that came with my setup is circular and was designed to go on the steering column. I installed mine in the kick panel cause I didn't feel like pulling the steering column apart, but if you are after something that will blend a little better it might be a better alternative than trying to code in a switch from a different car. Pretty good length on the wire too, so you might could get creative.
http://new.minimania.com/part/G3NMA1...56-F55-F57-F54
Old May 22, 2016 | 11:31 PM
Mini Mania's Avatar
Switch Needed
Thanks for help out devilmotorsports. Let us know if you need any help Vader!
simpsoap
Mar 25, 2016 07:24 PM
JWA
Mar 23, 2016 08:37 PM
Accessory Products
Mar 22, 2016 05:51 AM
Mar 22, 2016 05:50 AM
R53Minicoop
Mar 13, 2016 09:59 AM
