R50/53 Facelift Transmission Swap?
Old May 9, 2016 | 01:39 PM
sterlingarcher's Avatar
sterlingarcher
Hi All,
My 2003 MCS is getting close to needing a clutch. I'm thinking about picking up a good used 2005 or 2006 6MT to swap in when I do the clutch job (for the shorter gear ratios, which I think are much better matched to the car). I know it has been done before, but I'm not sure if I need anything else besides the transmission.
Thanks!
Old May 9, 2016 | 03:59 PM
Wertles's Avatar
Wertles
Nothing else needed than whatever you should change when doing the clutch. I did this three weeks ago. Externally, the boxes are the same.
Old May 9, 2016 | 05:42 PM
sterlingarcher
Excellent, thanks! I read somewhere that the cruise control doesn't work after the swap? Is that true?
Old May 9, 2016 | 07:37 PM
RB-MINI's Avatar
RB-MINI
I thought the cruise issue was going from a CVT to manual on an R50...
Old May 10, 2016 | 05:16 AM
Saltysalt's Avatar
Saltysalt
I would also verify if the shift cables are the same. I know there are 2 different shift boxes. but the cables might be the same.
Old May 10, 2016 | 05:44 AM
Wertles's Avatar
Wertles
Interesting. Mine quit working after the swap. By the scanner, it shows I have a bad button. Thought it completely unrelated but now I'm intrigued. Where did you read that?
Old May 13, 2016 | 09:36 PM
sterlingarcher
This thread here talks about it:
https://www.northamericanmotoring.co...e-control.html
I'll ask my local MINI specialists if there's something they can reprogram in the ECU to fix the issue. Should be.
Old May 13, 2016 | 09:41 PM
sterlingarcher
Oh, here. Says you'll need to have it recoded to get cruise control back:
http://www.minitorque.com/forum/f24/...nvolved-38364/
Old Aug 1, 2016 | 02:38 PM
sterlingarcher
Quick question: How much does the transmission/transaxle weigh? Like 200lbs?
Old Aug 1, 2016 | 04:27 PM
Shawnnn's Avatar
Shawnnn
Im sure someone knows how much, but my guess is 95 pounds or less. Its much closer to 100 than 200 lbs
Old Aug 1, 2016 | 05:54 PM
bavmotors's Avatar
bavmotors
Not sure what your concern is with the weight but from when mine was delivered it was able to be carried, I would say less than 200lbs. Cost me $150 to have it shipped.
Old Aug 2, 2016 | 04:41 AM
chris.j.lamb's Avatar
chris.j.lamb
realoem.com says 48kg so 105.6 lbs
2nd Childhood
Jul 27, 2019 05:45 AM
Mr. Krisztian
Apr 25, 2016 07:15 PM
Mister
Apr 18, 2016 05:20 AM
jcrane82
Apr 16, 2016 07:45 PM
808R53
Detailing 101
Mar 18, 2016 04:49 AM
