R50/53 R53 - Horrible Key Fob Range
Old May 8, 2016 | 03:50 PM
Andrew Riley's Avatar
Andrew Riley
So I've done the DiY mod to increase the range of the key fob.
Didn't help.
Changed battery.
Didn't help.
I measured the range to be about 30 yards right after I did the antenna mod on the fob. But now it seems as though it's slowly gotten worse... I basically have to be about 10 ft from the car now, it's so bad.
Anyone else ran into this issues? Possible fix?
Thanks guys!
Old May 8, 2016 | 05:44 PM
MiniTigger's Avatar
MiniTigger
Mine is about 30' from the car too. 06 R53.
Old May 8, 2016 | 06:04 PM
sevin's Avatar
sevin
Mine is pretty weak as well. A little trick I learned is to hold the key up to your chin before you press the buttons. Extends the range somehow. Usually it takes me a couple presses at ~30ft to get it to lock, but even at ~100ft with the chin method, works most every time.
Old May 8, 2016 | 06:25 PM
MiniTigger's Avatar
MiniTigger
I'll take your word for it.
Old May 8, 2016 | 06:31 PM
Andrew Riley
Chin trick is a huge help. I'm always using it, but in a parking lot with the car surrounded by big trucks and SUVs even that doesn't work... Just makes me look silly. So I try to play it off like I'm scratching my face with the key. :WINK:
Old May 8, 2016 | 08:39 PM
Fly'n Brick's Avatar
Fly'n Brick
Yup, it's true. Go back thru the forum into the 1st gen area and you'll find plenty of discussions about this. I do it all the time.
Old May 9, 2016 | 06:20 AM
Andrew Riley
Why is the range sooo shitty though? I remember when I got my first car (Ford Explorer), that keyfob would work well over 50 yards, reaching the car in the middle of a Costco parking lot. The panic button was awesome for when I couldn't find the car, lights flashing and horn blowing.
Has anyone figured out a way to make the car's horn go off when locking the doors?
Old May 9, 2016 | 06:41 AM
MiniTigger's Avatar
MiniTigger
If I had to guess, because the key is only but so big. You can only fit so much electronics on it.
Old May 9, 2016 | 07:06 AM
Swimbaxter's Avatar
Swimbaxter
Chin trick is the real deal.
xsmini
May 4, 2016 06:34 PM
5879
22
May 4, 2016 12:10 PM
buzzsaw
May 2, 2016 10:19 AM
sherry402
May 2, 2016 07:06 AM
keastman95
Apr 29, 2016 07:28 PM
