R50/53 Rally Lights for R53
Old May 4, 2016 | 06:50 AM
MiniTigger's Avatar
MiniTigger
Where can you get Rally Lights (driving lights) for an R53?
Old May 4, 2016 | 08:43 AM
RB-MINI's Avatar
RB-MINI
If you want plug and play, factory lights should be available at the dealer, ECS, or Pelican. For OEM lights with a generic harness and switch, look for Wipac lights on eBay.
Old May 4, 2016 | 11:19 AM
We are the go to on the OEM rally lights, we also have the most info on those:
https://www.northamericanmotoring.co...s-oem-hel.html
Otherwise you could get the PIAA ones or the Alta light bar and Piaa.
https://www.ecstuning.com/Search/SiteSearch/ES3032873/
PIAA /// Alta:
https://www.ecstuning.com/Search/SiteSearch/ES3103028__ES3103530/
Old May 4, 2016 | 12:00 PM
MiniTigger's Avatar
MiniTigger
What's the difference? Just looks? (2 more in the 4 bar would probably make it a little brighter)
Old May 4, 2016 | 12:07 PM
More lights , more sight
Old May 4, 2016 | 12:08 PM
MiniTigger's Avatar
MiniTigger
Which is the most popular? Factory, PIAA or 4 bulbs?
Old May 4, 2016 | 12:33 PM
The most Popular would be the OEM rally lights. Mostly because they were factory ( button and such ) and for resale.
Old May 4, 2016 | 01:09 PM
Capt_bj's Avatar
Capt_bj
I've installed several sets, some factory kits, and others 'generic'
comments:
the factory kit is overly complicated wrt the wiring. If you can live wit a simple generic on/off switch you can do all the wiring with about $25 from the electrical section of your local parts store
on the other hand the BRACKETS from the factory kit are a very clean mount and gives you the most OE look, no matter what particular light you choose. OUTMOTORING sells the brackets .... http://www.outmotoring.com/mini-coop..._brackets.html
if you have any questions feel free to PM me .... or if you live nearby I'll help you put 'em on (no charge)
p.s. some of these I installed... the owner did not plan to ever use them! So I installed lights and brackets but no wires!
Old May 4, 2016 | 03:37 PM
Da_Ghost's Avatar
Da_Ghost
comments:
Yeah, when I had mine, I wired them to a normal on/off switch. I didn't bother with the factory instructions that makes them unusable unless you are on high beams.
Old May 4, 2016 | 06:36 PM
MiniTigger's Avatar
MiniTigger
Agreed .. I would just want them to be on / off.
Old May 5, 2016 | 07:48 AM
Capt_bj's Avatar
Capt_bj
does your state require safety inspections?
TECHNICALLY these are supposed to be wired so they only come on if brights are on .... folks here have said their state checked for this .... I believe Jersey was mentioned... not an issue in the places I've lived since the MINI came out.
[BTW, factory wiring goes beyond this ... ensuring the lights are reset to 'disarmed' whenever the ignition goes off; and has a lighted status indicator in the switch]
Old May 6, 2016 | 06:23 PM
KevinR's Avatar
KevinR
I bought factory lamp brackets, console switch and wiring harness extension from ECS Tuning. Then I bought a set of new Hella 500FFs from ebay. I think I'm at $125 for the entire project.
Old May 6, 2016 | 06:55 PM
MiniTigger's Avatar
MiniTigger
Nice!
Old May 22, 2016 | 02:47 PM
LazyEar's Avatar
LazyEar
Is there a big difference between the halogen and LED rally lights? I'd love to add these in the near future, but am unsure which one to go with.
Old May 22, 2016 | 05:52 PM
MiniTigger's Avatar
MiniTigger
LED's would draw less power and be brighter.
Old May 22, 2016 | 06:09 PM
CRC's Avatar
CRC
Nice set up. What is the output like from the Hella's?
Old May 24, 2016 | 08:20 AM
Nice set up. I like your Aero front bumper
Old May 24, 2016 | 06:05 PM
KevinR's Avatar
KevinR
Thanks! The output is pretty good, but not quite as good as the output from the PIAAs I had on my previous MCS.
I need to find a way to stabilize the lamps. I get a bit of shake from time to time that gets annoying.
Old May 24, 2016 | 06:07 PM
KevinR's Avatar
KevinR
Thanks! I bought it used here in the NAM classifieds, already painted the correct color. I had to repair a couple of cracks and paint the black parts.
Old May 25, 2016 | 07:56 AM
Nice find, i want that next for my R52 MCC. But will not find it in Hot Orange.
Old May 25, 2016 | 01:10 PM
Mudhen's Avatar
Mudhen
I have Hella 500s as well. I ended up oval'ing out the holes in the factory brackets so I could slide them back to rest against the grill to stop them from vibrating. I put a couple pads on the back to protect them...wouldn't want to damage my precious grill!
Old May 25, 2016 | 01:58 PM
KevinR's Avatar
KevinR
I'm thinking lamp vibration is the least likely thing to damage your grill...
Old May 25, 2016 | 03:19 PM
Capt_bj's Avatar
Capt_bj
the factory kit includes a brace to control the bounce . . . .
Old May 25, 2016 | 06:06 PM
KevinR's Avatar
KevinR
I've got those parts... I'm just not sure how to install them and the instructions I have did not cover that. Also, the 500s are significantly larger than the factory lamps, so I wonder if they will even work with my setup.
Old May 26, 2016 | 08:04 AM
Do you need the factory OEM install. 63120144132
https://www.northamericanmotoring.co...em-switch.html
