R52 Seat height adjuster
Old May 3, 2016 | 06:39 AM
DaGriz's Avatar
DaGriz
Will not work if sitting in seat. Works fine with seat empty.
Worked fine before but now not even any resistance as if the handle isn't connected to anything, but when seat empty everything seems to engage fine.
Any suggestions other than adjust before you sit?
Old May 9, 2016 | 09:01 AM
You have to pump the seat up and down pretty hard ? Did you test and compare to the other side.
Old May 9, 2016 | 11:39 AM
DaGriz's Avatar
DaGriz
It was working prior so I am aware of how it should feel It doesn't seem to catch when you pump. But if you get off of the seat it works fine.
Old May 10, 2016 | 03:25 PM
isamin's Avatar
isamin
Are you too heavy?
ISAMIN
Old May 11, 2016 | 12:29 PM
Hit the gear on the bottom seat with some free all or oil. It might be binding under any weight.
neonsteve
R55 :: Clubman Talk (2008+)
Jul 4, 2020 05:40 AM
midwestinsocal
May 18, 2016 11:47 AM
Paul
Apr 29, 2016 12:19 AM
Coopercaba
Apr 28, 2016 04:27 AM
Frixos
Apr 26, 2016 02:03 PM
